Sore butt - any way to make seat more comfy??
I am enjoying most things about my 'new' 2008 C6 Coupe. But the seat leaves a little to be desired IMHO. I fully realize this is not a Lexus or Cadillac seat, but the seat seems HARD (the part your butt sits on). Plus, it does not seem to have any contouring at all.
Is there any way to soften this cushion up a little bit, or adjust the contour of the cushion?????
The back of the seat is fine, and it's very adjustable. It's just the seat cushion I am complaining about.
Any suggestions would be appreciated. Thanks, Dave F.
Night Race Blue 427
Location: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
If you have the seat lowered all the way try raising it up so you are not sitting on the floor board.
Common problem in older C6's.
http://forums.corvetteforum.com/c6-c...9-shipped.html
http://forums.corvetteforum.com/c6-c...eat-today.html
LOL, nope, I have NOT tried this. I am kinda tall (6'2"), so I likely have the seat all the way down. I would be truly stoked if this was my whole problem. I will adjust when I get home from office and see if that changes anything.....
Thanks for the suggestions!
Report back on how you made out.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I've thought about doing Don's suggestion above but mine is not uncomfortable yet. It is a relatively inexpensive fix, and from I've seen, not one for a highly sophisticated interior specialist.
I am 6"2" also. You cannot have the seat all the way down or you be terrible. raise it 1/2" and it should be fine
Yep, I had it all the way down and it was hitting the servo motor assembly. Kind of a pi$$-poor design IMHO. You woulda thought they'd have designed some clearance in there.
Thanks gents!!!!
Here is the rebuild kit from forum vendor....
http://www.southerncarparts.com/and-...it-p-3737.html
Over the last year or so, a solid repair process has been developed and we want to share it with everyone. We wanted to see how it worked out in my car for a year and can say I feel its 100% better than OEM. There are two problems: The side bolsters from the factory do not have any support under them. So as you climb in/out of the seat, the outside bolster foam tears where it sits on the steel seat frame and quickly sags or goes flat. The steel wires in the center area cut into the foam and quickly cause the foam to sag and pinching around the hip area. I found this extremely uncomfortable after only 15 minutes.
This seat rebuild kit comes with all of the seat foam insert pieces necessary to provide the extra support needed to give your Corvette seats a more luxurious feel. If you want to improve the comfort of your Corvette without replacing the stock seats, this simple and affordable kit is a fantastic means by which you can do this. Easily installable at home, this kit provides the extra, high-density, strong and comfortable foam needed to give your Corvette seats extra support and cushion to help make your Corvette interior more luxurious and enjoyable. A great way to improve comfort and drivability quickly and affordably.
This kit corrects a flaw in the original seat design that leads to premature failure of the center and bolsters.
The kit includes:
-Enough matierial to complete 1 seats
-Upholstery grade high density foam.
-Tough, wear-resistant ballistic nylon fabric.
-New, high quality, wire cover Jute Pad
-Zip ties to replace the metal hog rings.
-.25" thick high-density pad
-Detail step-by-step photo instructions.
Working slowly, it takes about 1-2 hours. The detailed instructions with photos will take you thru it step by step. No special skill or tools required although you will need to purchase separately a can of spray glue for upholstery foam.
The kit includes:
The kit includes:
The kit includes:
I have a question. Is this just on older C6s? I have no complaints about the seats in my 13GS. I'm only 5'8" but I like the front to be higher than the back (more upper leg support). So the rear of my seat is about as low as it can go while the front is slightly higher.
My suggestion:
