So I hit a raccoon last night and it messed up the plastic grill. How hard is it to replace? Also the the point of the front bumper by the head lights is now sitting higher like a clip broke, any suggestions? I have seen multiple vettes like this just wondering if there is a fix?
Replacing the grille is easy. There is a small plastic clip that holds the bumper cover down where it's raised in your pic. Even if you have to pull the entire bumper cover, that's pretty easy as well.
I would definitely recommend taking the bumper off to see the full extent of your damage, probably have some broken clips. I don't think the grille is really hard to replace.
If you need good instructions for removing and reinstalling the C6 front bumper, these instructions (in the PDF file) are well written. Used the instructions today top replace my GS grill and was able to remove and install in about two hours.
