LS3 question
Old Jan 1, 2014 | 05:43 PM
stp357's Avatar
stp357
Default LS3 question
Can someone tell me what RPM range is the sweet spot for shifting the manual transmission?
Old Jan 1, 2014 | 06:10 PM
SouthBaySurfer's Avatar
SouthBaySurfer
If you mean the sweet spot for max performance, I would say between 6000 and 6500 rims.
Old Jan 1, 2014 | 06:47 PM
stp357's Avatar
stp357
No, I mean the sweet spot for shifting from 2 to 3rd gear.
Old Jan 1, 2014 | 08:10 PM
Boomer111's Avatar
Boomer111
Sweet for what?
Speed, fuel consumption, smoothness through the gears?
The Tq and hp curves meet around 5250 rpm's. This would be for performance driving.
Tq moves the car hp keeps it there.
I personally do not see any reason to shift higher than this unless it is with a specific need for say 1/4 mile or road course to
My own personal opinion and others will argue.
Old Jan 1, 2014 | 09:07 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
For max acceleration, you normally want to shift at redline. That's slightly beyond the power peak, but after the shift is completed you are now carrying more rpm and thus making more power. That's why the A6 is set up to shift as close to redline as possible.
If you want to be a little easier on your engine, shifting about 500 rpm below redline is said to reduce the stress significantly, but I don't know how to test that out.
Old Jan 1, 2014 | 09:53 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Old Jan 1, 2014 | 11:19 PM
C7/Z06 Man's Avatar
C7/Z06 Man
Default Best acceleration, everything else is just commuter driving.
Read this a long time ago:
Shift 7 to 8% above your HP peak rpm for maximum acceleration.
Example:
Stock LS3 HP peak = 5900 rpm + 8%/472rpm's = 6372 rpm's.
Works for me.
PS: Shifting higher is only making noise "AND" slowing you down. With my "A6" shifting at approx. 6400 rpm's the engine falls back around it's torque peak of 4600 rpm's which is good for acceleration & not bogging the car down.
Old Jan 1, 2014 | 11:51 PM
stp357's Avatar
stp357
Originally Posted by Boomer111
Sweet for what?
Smoothness through the gears is what I am after, remember I am about to be a brand new Vette owner. Max speed for me is a bit down the road.
Old Jan 2, 2014 | 12:26 AM
C7/Z06 Man's Avatar
C7/Z06 Man
If I am driving any stick "normal" I shift at low rpm's unless I want more acceleration than I will raise the rpm's depending on how much pickup I'm looking for at the moment just like any other car.
PS: An automatic works the same way; with little gas an A6 can be in sixth gear in "very" short order but floor it and it's a whole different story. I know what you are looking for and you will find it in short order after you start driving your car. Good Luck.
On your 2 to 3 shift you may like running second gear up higher or lower to a degree than the next guy.
What I do in our 5 speed stick M3 BMW is try to shift were the person sitting next to me and "me" can not even "feel" the shifts, period. 1,3,5 works pretty good for smoothness in that car.
Old Jan 2, 2014 | 08:36 AM
Boomer111's Avatar
Boomer111
Well I have changed the differential from the stock 3:42 to 4:10's.
But I usually shift while just cruising over 2,000 and under 3,000 rpm. Now I can shift much earlier and much higher but right around 2,5000 give or take a few hundred rpm's you will find it to be pretty smooth. At 3,500 the car starts to wake up.
My comment on the 5,200 rpm max shift was with longevity in mind and not all out time elapsed speed.
I agree with Gearhead Jim's assessment for all out performance under the clock.
Old Jan 2, 2014 | 08:45 AM
dvilin's Avatar
dvilin
For what you are asking I would say around 2500 RPM's would be a smooth/sweet spot shift point.
Old Jan 2, 2014 | 11:06 AM
Al Gumby's Avatar
Al Gumby
My car likes 3K rpm for normal driving. It's just right for smooth shifting, decent acceleration and engine music. Not so good for fuel mileage.
Old Jan 2, 2014 | 11:49 AM
smurfkiller's Avatar
smurfkiller
just wait till it hits the rev limiter 7 to 10 times then shift.
Old Jan 2, 2014 | 02:24 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
around town 2500 rpm's.
Old Jan 2, 2014 | 03:11 PM
96GS#007's Avatar
96GS#007
It's a car. Shift when it feels right/it feels comfortable to you. One size (rpm) does not fit all. Speed, desired acceleration (no matter how minimal), incline of the roadway, etc all play a part.
Old Jan 2, 2014 | 04:44 PM
trebor8008's Avatar
trebor8008
As you acclimate to your car you'll develope your shift pattern. But, like everyone says here, 2500 rpm is not a bad place to start.
Old Jan 3, 2014 | 09:32 AM
SouthBaySurfer
I'm surprised no one has mentioned the 1-4 skip shift yet.
Old Jan 3, 2014 | 04:14 PM
PRE-Z06's Avatar
PRE-Z06
Example:
Works for me.
500rpm past peak is a good rule of thumb and should put you past peak torque rpm, but you really want to look at the shift extension or rpm drop of each gear for the greatest average power equalling max acceleration.
Old Jan 3, 2014 | 05:45 PM
Bill Dearborn's Avatar
Bill Dearborn
The Vette has an engine that produces lots of torque at low speeds. You can easily shift from 1st to 2nd at 12-14 mph (this also avoids skip shift), shift from 2nd to 3rd in the low 20s, shift from 3rd to 4th in the high 20s, shift from 4th to 5th at about 35, shift from 5th to 6th at about 45 mph. If you have the Z51 or Gran Sport transmission manual transmission with the lower gearing you can reduce those speeds a few miles per hour. If you are trying to accelerate as fast as possible then you want to shift at or around 6400 rpm. The problem with doing that is keeping your eyes on the road and the tach in the lower gears as 6400 comes up damn fast through the first two gears and pretty fast in third.
Bill
To LS3 question
