Deltran Battery Tender Plus
Old 02-28-2014, 04:43 PM
APLark
APLark's Avatar
Default Deltran Battery Tender Plus
I just purchased a Deltran Battery Tender Plus. Sometimes I go weeks without driving the Vette. Can it be left on the entire time? Any suggestions?
Old 02-28-2014, 04:55 PM
R&L's C6
Support Corvetteforum!
R&L's C6's Avatar
Received 1,249 Likes on 706 Posts
I have the Deltran Battery tender JR. and it stays on my car from October to April. Never a problem.
Old 02-28-2014, 05:33 PM
Homer3D
Homer3D's Avatar
That is what battery tenders are designed for.
Old 02-28-2014, 07:21 PM
dvilin
dvilin's Avatar
Received 7,922 Likes on 4,808 Posts
Old 02-28-2014, 07:29 PM
TerryL
TerryL's Avatar
St. Jude Donor '17
Absolutely, and the Plus is better than the Jr for a car battery.
Old 02-28-2014, 07:34 PM
not08crmanymore
not08crmanymore's Avatar
Why yes,Yes it can!! That's it's job.
Old 02-28-2014, 07:37 PM
R&L's C6
R&L's C6's Avatar
How so?
Old 02-28-2014, 07:41 PM
DezVette
DezVette's Avatar
This looks like an interesting product for use with the battery tender.
Old 02-28-2014, 08:43 PM
APLark
APLark's Avatar
I would like to thank all of you for the information that you have provided.
Old 02-28-2014, 09:10 PM
TerryL
TerryL's Avatar
St. Jude Donor '17
How so?
Someone on this site explained it better than I can recall. Had something to do with reducing the sulfating on the plates that occurs in the battery as compared to a much smaller motorcycle battery. I use Jrs on my motorcycles but they're only around 300 cold cranking amps. The Vette's battery has 600 or more CCAs. The Jr charges at .75 amps and the Plus at 1.25 amps. You're proof that it may not really matter but maybe the battery will last longer using a Plus vs the Jr. My bike batteries typically last six years or more, one lasted over eight years and they're always on Jrs unless I'm riding them. Deltran makes good stuff!
Old 02-28-2014, 09:15 PM
Gary '09 C6
Gary '09 C6's Avatar
Deltran does make good stuff !
I once read on Deltran's website that they recommended the Plus for Corvettes (as opposed to the Jr.)
due to all of the electronics/modules being active for longer after the car had been shut-off.
I'll see if I can find that again...
saplumr
saplumr's Avatar
Received 1,251 Likes on 895 Posts
I have a single on the car and a four bank handling other batteries for 5-6 months of winter weather...full time connect.
Old 02-28-2014, 11:41 PM
Sunset-C6
Sunset-C6's Avatar
NO,NO......don't leave it on the entire time.....remove it before you take the car out for a drive, unless you have a very long extension cord on the battery tender.
Old 03-02-2014, 07:10 PM
zero11
zero11's Avatar
plug it in and forget it,they are safe .The plus is better for the larger car batteries,the jr for smaller batteries such as riding mowers.
Old 03-02-2014, 07:31 PM
Red08
Red08's Avatar
Received 1,441 Likes on 780 Posts
Yes, it is designed to by used 24/7
Old 03-03-2014, 03:26 AM
hihocarp
hihocarp's Avatar
I've used the jr for the past 3 years throughout the winter and my car starts every time plus it's still the original [5 years old]
Old 03-03-2014, 02:03 PM
ButWhatDoIKnow
ButWhatDoIKnow's Avatar
This should be in the instruction booklet.
Old 03-03-2014, 03:42 PM
USA1 427
USA1 427's Avatar
Right now I'm using the battery tender that came with the car. But I used the Deltran on my last Vette when I stored it during the winters and had no problems whatsoever.
To Deltran Battery Tender Plus
Quick Reply: Deltran Battery Tender Plus
