Center console air vent remove and replac?
How do the vents come out of the console, I see screws behind the vents with the console pulled out .. Assuming the screws need to come out.. Will the vents come out once screws removed?
Thanks in advance.
Thanks in advance.
Race Car Tech
The vents are held with 4 corner tabs in the back of the console. They can only be accessed if you remove the radio surround console.
I can get you a pic if you need to see the tabs from behind.
Are you referring to the vents that are part of the surround, or the actual ducts that bring the air in?
