Heated seat module connector
Hey everyone. I just bought an 07 z51 a couple weeks ago, and neither of the heated seats were worked. The passenger side was an easy fix, the switch under the HVAC controls wasn't plugged in. The driver's side wasn't either, but it didn't work after plugging it in.
Today I pulled the seat out, and noticed the connector was not plugged into the module. The module and connector both have the ground wire burnt, which apparently was a pretty common problem. I found the module online to buy, but I can't find the connector itself. Anyone know where I can buy one?
Thanks guys. I looked on gm parts department's website and I can find the seat module, and what looks to be the whole seat harness, but I can't seem to find just the single connector. It's the 10 pin that goes into the heated seat module. I'd really hate to have to spend $100 bucks on the whole seat harness just for the connector. Any ideas?
Them module is #26, the harness i found is #17.
http://www.gmpartsdepartment.com/par...gramCallOut=26
I would call GMpartsdirect and talk to them to see if they sell the part you need seperately, also they can verify the part is the correct one for your car before ordering it.
If you can't get just the connector from GM, you can try contacting Forum Guru Ray Kawal.
He may have a source/part number for this.
I ended up going to a local gm dealer and he found a part number for the connector and pigtails, but they wanted more than the whole harness from gm parts department. So I ordered the module and the harness, then recieved an email saying they could no longer get the harness. So I'm back to square one with the connector.
