* * * * DANGER Fuel Leaks - SAFETY RECALL * * * *
Old 04-02-2019, 07:00 PM
  #1081
acf5678
CF Senior Member
Liked 0 Times in 0 Posts
My 09 had 12000. wow I have to drive it more.
acf5678 is offline
Old 04-17-2019, 12:26 PM
  #1082
kfede1
CF Senior Member
kfede1's Avatar
Liked 1 Time in 1 Post
Default Bas gas smell, only 1/4 tank. Reliable Chevrolet not cooperating.
Hello guys. I had the issue occur a week ago. Really bad gas smell. and I only have 1/4 tank in it. I had it at the Reliable Chevrolet in Richardson Texas and they say they did a "smoke test" and everything is fine. They won't do any more unless it catches fire I guess. They did not take the wheel of or actually look under the skin, so I am under the opinion they did nothing useful.
Any suggestions? I did already file a complaint on the site mentioned in several other responses, but that seems to go no where.
kfede1 is offline
Old 04-18-2019, 01:02 AM
  #1083
Bob Paris
CF Senior Member
Support Corvetteforum!
Bob Paris's Avatar
Liked 161 Times in 98 Posts
[QUOTE=kfede1;1599243088]Hello guys. I had the issue occur a week ago. Really bad gas smell. and I only have 1/4 tank in it. I had it at the Reliable Chevrolet in Richardson Texas and they say they did a "smoke test" and everything is fine. They won't do any more unless it catches fire I guess. They did not take the wheel of or actually look under the skin, so I am under the opinion they did nothing useful.
The fact that you do not have full or nearly-full gas tanks make me think that something else is going on. GM has dealers diagnose with the "smoke test" to indicate a leak and if none was detected then you may not have the covered issue. Shouldn't smell gas so keep on this. Good luck.
Bob Paris is offline
Old 04-18-2019, 08:00 AM
  #1084
roger55
CF Senior Member
roger55's Avatar
Liked 4 Times in 3 Posts
Since this is where the problem occurs, it doesn't matter what the fuel level is. It will leak whenever the engine is running and the fuel pump is maintaining pressure in the line.
roger55 is offline
Quick Reply: * * * * DANGER Fuel Leaks - SAFETY RECALL * * * *
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
