Best battery for C6 (Die-hard or Interstate)
Die-Hard and Interstate are both made by the same company - Johnson Controls. Johnson Controls also makes all of the Optima's. I prefer Interstate. I've never had an issue with one and there is very likely a dealer within walking distance of just about everywhere. Plug in a zip code, ANY zip code and see - http://www.interstatebatteries.com/d...r/default.aspx Now try that with Sears or even a GM dealer.
Interstate, used them for 40 years, never had a bad one.
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I have been using AC Delco for years in my Corvette with no issues.
Red top optima for me. When spring time comes i'm ditching the stock battery for one.
Ran a red top in my last car. Flawless.
I understand that you are not asking about Delco's but I have used them for decades. Even use the voyager in my boats. Never any issues, not even with the one in my 07 that will be 8 years old on January 2nd. A good Ctek tender (which I use on my vehicles that are GQ's) will give you extended life out of ANY battery if your car is not driven daily, FWIW.
[QUOTE=RobGZ06;1588563715]Red top optima for me. When spring time comes i'm ditching the stock battery for one.
Same plan for me in my 2011 GS... plan on replacing it before it is a problem.
Retired & lovin' it!
I just put a red top Optima in my 08,
Sounds like when I need one I'll go with the Optima but when I needed one for a Trans Am, I bought an Autozone and after eight years it was still going strong when I traded it in for the Vette!
I'm a cheap skate always looking for a good deal....so it's Costco and Walmart. 6 year warranty with the first 3 years at no charge (sic).
Regarding CTEK battery tender, consider their US 4.3 over the 3300. Comparable price with 8 stage charging and 4.3 amps vs 3 stage and 3.3 amps.
A great holiday to all and keep the shiney side up.
