Hammy's Grand Sport Bar & Grill
Received 2,882 Likes
ROCKETMAN, it might be easier to pour rock salt in the downspouts than move. Just saying.
Pro Mechanic
Received 3,938 Likes
hoping that I got most of the issues addressed today.................... water was backing up and the backyard area stays wet most of the time, due to lack of sun because of trees, and I am at the lowest point on my block with the end of the block about 20 feet higher than me...............
just sick and tired of the stupid rules enforced by a bunch of no nothing, do even less asshats.............................
the drains are ABS plastic tubes, placed underground and run as a drain system where they come up to ground level and have a lid with a cap that pops up to allow water out...................
no map of the system................... not the first time I dealt with it here, had to do the front and side a few years ago................... made my own maps of the routing then.................... can't cut the trees out on my own, they are on "common grounds" and the association won't remove them due to costs.............
fighting a loosing battle here....................... will try the salt tricks if it persists
Just put a cup or so in each downspout 3 or 4 times a year.....no more roots in the pipes.
Could not live in a HOA neighborhood. Bad enough with the city changing regulations. They passed a code about placements of sheds and nowhere on my property would meet their code. Put one where I wanted it anyway.
Pro Mechanic
Thank you! Great advice! If I didn't get this for about 1/3 of value, I would have not bought it....................... now it is my "retirement" nest egg..............
Well my son and his best friend just stopped by to show off his new to him car. His friend bought a 2017 Camaro 2SS. White with black and red interior. Nice car!! HUD, keyless start, mag ride, Brembo 6 and 4 piston calipers and hill assist.
455 hp LT1 4.1 sec 0 to 60.
Car has 4k miles.
Think I might have to bring him back down to earth.
Car has 4k miles.
Received 2,060 Likes
No man's land is a lie. There are thousands of people there. People/property owners in Nome Alaska are Nomans and their land is obviously called Noman's land. In other local news, Gnomes are a popular yard ornament normally made near Nome by Norman Neumann the Noman Gnome builder of North Nome.
Received 3,611 Likes
2016 C6 of Year Finalist
I've been thinking ceramic, too. I've gotten to where I take the vette to the carwash It's a touchless and it sprays soap, rinses, "wax", rinses, and blow dries. I spend about 10 minutes walking around with a towel and it's good enough for the street.
In other news, Thanks to my girl or, ex or whatever the **** is going on, I have spent most of the day agitated so I spent time on the RX7.
I stripped the engine down, cleaned the 10 years of dust from it, moly coated the bearings, checked clearances, reassembled and torqued everything down. If my agitation continues into tomorrow I might just bolt the heads down and degree the cam.
Ummm, I can only say...I hope H1 made my world famous Pink Panty Pulldowns...in a huge vat. The corn fed buffaloes rolled to a 33-28 victory. Bummer.
Pro Mechanic
With the ceramic I don't even have to dry it, by the time I get home it's dry.
Shaolin looks good...……………………. just a couple things that caught my eye...………… why does it look like 1/3 of the valve reliefs in the pistons are so clean and bright compared to the rest..... also saw some type of marks on the outboard side of the lower cylinders on 7 of the 8 bores...…………. I know it was given to you "as is" just thought you may have some idea of the history...………
Shaolin looks good...just a couple things that caught my eye...why does it look like 1/3 of the valve reliefs in the pistons are so clean and bright compared to the rest...also saw some type of marks on the outboard side of the lower cylinders on 7 of the 8 bores...I know it was given to you "as is" just thought you may have some idea of the history...
But, then hell, it's a Ford. Maybe that's how they put them together...with a big hammer.
Pro Mechanic
as far as the Husker game...………………. I did see the 57 yard TD from the Husker QB to the receiver that put them ahead...…………. was a very nicely executed play
didn't see anymore until there were 2 minutes left and Huskers up by 1...…………. Colorado was pushed out of field goal range, then a dumb penalty gave them a first down...……… poor choice by the Husker defender.....
then the icing on the cake was a beautiful backshoulder fade route to the Colorado leading receiver for a TD...…………….
Husker starting QB was out of the game with knee issue, so the back-up came in, led them down the field, but last gasp effort was out of bounds...……………
H1 saw a very good game, just too bad someone had to lose...………… Huskers will be OK, as long as the QB isn't hurt too bad...……….. first year under Frost, but headed in the right direction from the effort shown today
It's just a weird photo of the oil pool up that dripped to the bottom of the cylinder. This block wasn't cut to clear a larger stroke. Unless you're talking about the casting build up from where it's cut from the molds. Either way it was freshly honed but just has the typical tarnished cast iron look. Everything checked out .003 piston clearance and .025/.025 on the rings, .001 on aft clearance, and .0015 on the bearing before coating.
Gave up watching the Texas Tech game when it was 42 to 0 at halftime. Think Tech was playing Lamar High school.
Did I say go Cougs?
