Driver display says "Left front tire flat" anyone else?
I got 2 new front tires Friday July 24th no problem on way home or short drive then drove to gas station and the message came on. After that the :check fuel system" light came on on way home but didn't come on today . Drove to Pawley's Island (340 miles from home" the tire message never came on until we stopped for lunch. Came on and went back off. I checked tire pressure before leaving had 34 all around. Oh, and theee dealer did a 4 wheel alignment.
7th Gear
Two or three times a week for just a few minutes mine would read flat for the right rear. Bought a new OEM unit from Amazon and had it installed. Works perfectly as do the other three originals. BTW 34 psi is too much for a cold tire.
What should it be? The dealer had 36 in both new front tires and the sidewall had a max of 38. They are no high end Z rated tires but a set of continentals they had on sale (so they say)
The speed rating is right on the sidewall...you don't need to take the dealer's word for it. For example:
285-35-ZR-19 93Y......"Y" is the speed rating (186mph).
Unless it's a snow tire, it would be unusual for a tire made in a Corvette size not to have at least a "W" rating.
Received 3,625 Likes
2016 C6 of Year Finalist
I have a 2007 that just began to do the same thing only for the right front tire. I found out as you will see from other replies that the sensor battery goes bad. Heard that the OEM sensor is from Schrader and that is the best to do to replace them. Also found out from a tire dealer in my area that my mechanic took the car to said that as long as there is air when you check with the gauge it is OK
The sidewall shows the maximum pressure that the tire should have and not what the cars manufacturer designates it to be. The cold temp on the C6 corvette is 30psi which will max out at around 34 when the tire is hot.
From the owners manual:
"A Tire and Loading Information label is attached to
the vehicle’s b-pillar. This label lists your vehicle’s
original equipment tires and shows the correct
inflation pressures for your tires when they
are cold. The recommended cold tire inflation
pressure, shown on the label, is the minimum
amount of air pressure needed to support
your vehicle’s maximum load carrying capacity.
Inflation - Tire Pressure
Tires need the correct amount of air pressure to
operate effectively.
Notice: Do not let anyone tell you that
under-inflation or over-inflation is all right. It is
not. If your tires do not have enough air
(under-inflation), you can get the following:
• Too much flexing
• Too much heat
• Tire overloading
• Premature or irregular wear
• Poor handling
• Reduced fuel economy
If your tires have too much air (over-inflation),
• Unusual wear
• Poor handling
• Rough ride
• Needless damage from road hazards"
