using a battery tender with the hood closed
The whole idea of a battery tender is that they will NOT destroy the battery by overcharging and breaking down the electrolyte. You will get NO fumes other than an extremely tiny amount of water vapor from a battery on a tender/maintainer.
Received 3,623 Likes
2016 C6 of Year Finalist
Using a maintainer can easily double and possibly triple the life of a battery. The difference between the most expensive and least expensive is not significant. The smaller (lower the current), the better. It is a maintainer, not a charger, so how fast it can bring the battery up to full charge should be unimportant. I have a couple of Battery Tender Jr.s that have worked great even when left on an unused car for several years continuously.
I have been using CTEK's for years. My 07 will be 9 years old January 2nd and it still has the original battery in it. There has been no hint of its demise as of 10 days ago when I drove it. I have also used a Battery Butler in the past with great results. Hood is closed, car up on lift, there is plenty of air circulation with the hood down. FWIW.
*my results are not the typical tender users results. I am a professional, do not try this at home kids. Adult supervision is suggested...
#34
St. Jude Donor '15-'16
snaking it thru the gap next to the engine. After the engine fully cools
of course.
#36
The Black and Decker is at Home Depot also...nice because it comes with all three connection adapters included. $22
Also at WalMart $18.99, just don't take the Vette to Walmart...you'll catch all kinds of hell on the forum.
#37
older cars don't have the draw on the battery that the newer ones do, they can be on a tender without being hooked up. when we go to Arizona for a month i keep a tender on my DD while we're away also
