Broken terminal connector?
Went to install a new battery tender connection and discovered this. Changed the battery out during the summer, and maybe over tightened at that time. Suggestions? Do they even sell just that part of the connector? Maybe a small band clamp just around the terminal? On the positive side of the battery.
tloon (10-31-2015)
tloon (10-31-2015)
tloon (10-31-2015)
tloon (10-31-2015)
Received 1,194 Likes
St. Jude Donor '15
Replacement cable is $50, not exactly a fortune. Positive and negative cables come together as an assembly, so you get both for the $50
I bought a new set but am going to try just replacing the connector itself first. The GM ones look really cheap and it will be an easier install to just cut the old connector off and install a heavier duty one. We'll see how it goes tomorrow.
tloon (10-31-2015)
St. Jude Donor '15
You can't get the negative cable off without removing the positive cable too. They both run down near the starter and I know positive runs to the fuse box also.
I'll let you know how it goes replacing just the connector
tloon (10-31-2015)
Please, let me know how you make out. Was thinking I could just remove that broken part from a new cable connector and install? Anyone know where that negative battery cable connects to the frame? I have the E-Force on this and a lot of the intercooler plumbing had to come out for me to replace the battery. Not looking forward to that again.
tloon (10-31-2015)
St. Jude Donor '15
Not for OEM cables!! The positive cable is over $100.00 plus. And to replaced it you are going to have to unwrap the old cable to install the new one and wrap it.Takes only about 1/2 hour to replace both connectors to the battery terminals. I would like to know where you get both cables for $50 bucks..I know (Fleabay).
I could not find a part number for only one cable. They both had the same part number so I assume they come as an assembly. Are you sure they come separate and require wrapping, etc. or are you just assuming that?
I am going to try to remove that broken part of the connector. If I can safely pry that piece of metal back up part way it should come right off. I would pay the $60.00 or so on E-bay for the new parts and just take that clip off.
St. Jude Donor '15
Here's the one I bought:
If you look close you'll see both red and black connectors
If you look up the part number for a positive battery cable it will say "included with negative side". The GM Book price is like $75, so I'm not sure where anyone is getting $100 from. I'll be happy to sell you one for that if you'd like
http://www.gmpartsdepartment.com/par...iagram=CF05085 look at #8
I promise you, the AC Delco one is the same thing. GM doesn't make stuff like this, they just buy it from someone. This just cuts out the middle man.
Amazon.com: ACDelco 15832652 GM Original Equipment Positive and Negative Battery Cable Assembly: Automotive
tloon (10-31-2015)
after awhile the oem cable clamps become warn an nolonger tighten as they should. i tried cutting the end clamps off an replacing them with after market clamps but the cable itself became brittle an fell apart so i ended up going back to the oem cables. to replace the cables wasnt that big a deal, just be sure to remember or mark the ends then match them with the new cables.
Amazon, actually . Search on there for part number 15832652. Came in GM packaging, included both cables and they already had all the heat shielding and such installed. $48 delivered in two days. Can't beat that.
Ordered what are supposed to be the correct pos and neg cables from a local Chevy dealer this am. Said it is in fact one single unit, and not able to purchase seperately. Charged me $79.00 for the whole thing. I temporarily used a stainless steel band clamp around the pos terminal connector, and it worked great, tight as hell. Could probably leave it like that and it would be fine. Cannot even see it under the red boot cover. Took the car for a quick burn on a beautiful fall New England day. Things may be looking up!
St. Jude Donor '15
I checked the link to Amazon you went to and I checked from 2007 to 2013 corvettes and got the pop up in RED this does not fit your corvette The dealer gets $137.05 just for the positive cable Part# 20835504.Better do some more research because a lot of GM cars has the same crappie connector. There was a thread a couple of years ago and one member put up some photos of the connectors he put on his. He got them online. All I did was cut the OEM connector off where the cable is crimped on the copper wire and put a brass one on with blue Loctite. I'm old and slow, so it took about 1/2 hr and less then $10 bucks..Good Luck
I do believe you're right about the part number. Mine is a 2005, so that is the part number I looked up and the one I purchased. Whether it really won't fit a 2007, I have no idea.
Here's the correct one from amazon for 2007's and newer. Still only $65
Amazon.com: ACDelco 20835504 GM Original Equipment Positive and Negative Battery Cable Assembly: Automotive
See pictures below.
Notice the positive and negative cables have the SAME part number. Then.. notice the note under the positive one. It clearly states it comes included with the negative. Believe me yet?
Also worth mentioning is the price. Hardly $137, and this IS from a GM dealer.
BigMonkey73 (11-05-2015)
St. Jude Donor '15
And last but not least.. I changed only the ends on mine too. I changed them both while I was at it, $9 a piece.. voltage on the DIC is higher and my fuel pressure is up a few psi, so overall I'm happy.
Old end
New negative installed. Not loving the not so factory look but whatever.
Positive done also
Ew
Old end
Positive done also
Ew
