Neutral position indicator ?
Received 1,596 Likes
The computer does know what gear you are in at any given time, so I guess it would know when you are not in gear too. Not quite sure how you would hook it up though.
Landru (12-06-2015)
Here u go Simple. Tells you what gear your in and 0 neutral. I have it. Love it
http://www.speedhut.com/gauges/sstmax/search:sstmax
I never said I didn't know what gear I was in, or where neutral was. Yes I can wiggle the shifter to see if I'm in neutral. This is a mod that I wanted for MY car, if it is something you're not interested in, no need to bash.
When you're driving along with cruise control and pop it out of gear, the revs will climb for a bit then cruise will disengage when it realizes you're not picking up speed.
The car knows through the CAN bus what gear the trans is in at all times, the cruise disengages as soon as you clutch in. If you have ever done any diagnostic work with a Tech II connected you would see the selected gear appear on the real time display.
To "test" the cruise control logic. I "test" out every manual car with cruise control to see what it does when you move out of gear w/o clutching; just to see how it reacts.
If it were to know what gear you were in at all times, would it not immediately know you're in neutral and disengage cruise?
