CoW WOW! not even close!
WOW! is not descriptive enough!
I just installed it and took her on a test drive. You have no idea of the difference in the pedal-throttle response until you do this very inexpensive mod. Throttle response is instant. In gear idle is the same, but you lay your pinky toe on the pedal and off to the races you go! Chuck probably should include a warning to have lids on liquids and secure your belongings before touching the pedal.
Do this mod and discover why there are headrests!
Thanks Chuck!
Thanks Chuck!
Chuck CoW (01-09-2016)
Should have looked at the Vitesse Motorsports Throttle Controller. The easy install and adjustable settings was what sold me.
Received 1,596 Likes
Always on 9
The following 25 users liked this post by EVRose:
4R27TH (12-16-2015),
bhoch (12-15-2015),
BRussell (01-14-2016),
Cherokee Nation (03-21-2018),
Chuck CoW (12-15-2015),
and 20 others liked this post.
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
FOOLING with WIRES WILL GET YOU STUCK - READ HERE --->
FOOLING with WIRES WILL GET YOU STUCK - READ HERE ---> Need Help with Vitesse Throttle Controller!!!
FOOLING with WIRES WILL GET YOU STUCK - READ HERE ---> Vitesse Throttle Controller Questions
FOOLING with WIRES WILL GET YOU STUCK - READ HERE ---> Vitesse Throttle Controller WOT Issuses
FOOLING with WIRES WILL GET YOU STUCK - READ HERE ---> Vitesse Throttle Controller causing issues?
FOOLING with WIRES WILL GET YOU STUCK - READ HERE ---> Vitesse throttle controller issue
Just some of the reasons you should stick with the ORIGINATOR of LS Throttle BOOSTING!
CoW BOOSTER! has 1,000's of sales and never ever once one problem. Still the ONLY 100% safe throttle BOOSTING product.
Why would you take chances having the throttle stick open or yet....CLOSE and shut your car down????
Chuck CoW
Chuck CoW
Love mine.
Chuck CoW
Chuck CoW
Dave
