Cow Boost Tune and 342's
I must say this is the best I could ask for. I stopped by Chuck Cow and left with the biggest smile ever. You can't believe the difference. Had the Engine and Trans tune also the COW BOOSTER and a 342 installed. I am still getting use to it. Chuck You are the best. Thanks Bill K Willis
Chuck CoW (12-26-2015)
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Thank you my friend!
People stupidly shop for "HORSEPOWER" as if that was the only valid "performance" type of mod.
I always make sure that you're properly advised before you mod as most often things you never would have
considered suddenly become reality as with the 3.42 package.
You would have to add a lot of horsepower and spend a lot of money just to give you the same "performance"
as our 3.42 rear end does. Quite, reliable, and FAST!
Thanks for the nice review!
Chuck CoW
At 70 I am up about 250 rpms. I am very happy even at highway speeds so responsive touch and go on the pedal. This is a must as far as I am concerned. Best mod ever for me. Combine it with a tune and Cow you can't believe the difference.
Not bad. I have done a couple rear diff. gear swaps on a couple times in my life. I am not doing this with the cow thing but doing thru a shop here in Dallas that specializes in gear swaps. I also picked up my Vitesse Throttle Controller today. Will install mañana. Thanks for feedback.
Former Vendor
Thank you!
Thank you! Typically, our 3.42 Rear End cruises at 70 MPH at 1,975 rpms and fuel mileage is not effected.
The reason is that with our rear end the rpms go up slightly BUT, engine load goes down because the rear end helps
move the car easier at the elevated rpms so the driver needs to apply LESS throttle and you save fuel.
Add to that the Amazing CoW BOOSTER! which has been proven to add between 1 and 3 mpg in Vettes and you're
fast as hell while still saving fuel.
While fuel mileage is usually not a concern for most vette owners, if it is actually we can use our autocal to change
the settings for even better economy when necessary....
For those that have decided to go elsewhere.....too bad.
If you talk nice to me I'll always take you back! and you'll have the ABSOLUTE BEST product available.
Thank you!
Chuck CoW
Received 3,626 Likes
2016 C6 of Year Finalist
I do not claim to be an automotive technician but, using your logic I should get better mileage in 5th than 6th.
I had my tune booster and 3:42s for a while now and still love them. I went from 28 mpg to 26 mpg on the highway but the difference in performance is well worth it. I think I tend to get on it a little more now than before. Thanks Chuck!
Former Vendor
Thank you Ed!
Certainly it depends on how you drive.... I tune most cars like I did yours with the emphasis on PERFORMANCE.
If a customer is really dying over the 2mpg.... I can make some adjustments in the tune to make up for that pretty
easy, but again.... FAST is what Ed's got and FAST is what most wanted.
Between the CoW BOOSTER! and the 3.42 REAR END, you barely touch the gas and the car just goes.....
I've had supercharged C6's (stick) with 4.10s in the rear end get 30 MPG on the highway....
YES, it's totally possible if you know how to do it.
But, HEY.... You ain't drivin no PRIUS....Right?
Chuck CoW
Bill you just made the same post on the 20th. Reporting to the mods for double post.
https://www.corvetteforum.com/forums...chuck-cow.html
The longer you've been on the forums the more obvious these games become. Damage control. Very predictable.
Chuck CoW (12-28-2015)
