Vitesse: Throttle Controller Install w/Pics
VITESSE : Throttle Controller
Here is the install instructions from Vitesse’s web page …I have simply added pics and some clarification? (clarification in bold) since I installed it today. It’s a real easy install allot of people were wanting pics so hopefully this helps someone.
Instruction on how to install:
- Switch off the car for at least 5 minutes and key off.
- Make sure the car is on the Parking position or Neutral.
- Push your driver seat all the way to the back to give you enough room to access under the dashboard.
- Remove the plastic panel under the dash to have an easier access to your Gas pedal harness.
I have a 2012 Grandsport should be the same for everyone?: The plastic panel has three bastards you have to get out…
I have a trim kit if you don’t have one, get one they are like 18 bucks on amazon and are worth every penny.
Once you get the bastards off you will have easy access to the gas pedal.
- Unplug the Harness on top of your Gas Pedal (First you will need to push up the securing gray pin using a flat screw driver, after that while squeezing in the middle of the harness, pull the harness upward by holding the plastic connection, not the wires!
I was able to pull up the gray tab easily with my finger nail. You then press this area on both sides and it lifts right off.
- Now you can plug the harness that comes with the controller, male to female and female to the Gas pedal harness.
The optional yellow and blue wires on the main unit will not be used now. (Brakes / Launch Control option)
The rest is easy…that’s all…..
I tucked the unit back here.
I ran the lines along the side they tuck right in here.
Used Industrial strength Velcro - wipe area with alcohol that you are going to place the velcro.. :
Here is where I placed mine….unsure if my leg will hit it so I may change its location but It looks cool to me.
The programming is easy. Just follow the instructions exactly and your good.
Makes the car feel really responsive and with my newly installed C5 spring and this....I am off to slaughter sissy boy Porches and BMWs...
The following 8 users liked this post by Cor430vette:
Carvin (03-31-2016),
corvette_manX (01-27-2016),
dmk0210 (06-18-2016),
ncvette_1FUNRIDE (01-25-2016),
Norskie (04-26-2016),
and 3 others liked this post.
Cor430vette (01-26-2016)
Originally Posted by kmvp860am
Thanks for tbe instructions/photos. I also has a 2012 GS. Do you think the wires are long enough that I could put it in the center storage compartment?
Thanks for the write up and pics. I have had the controller for a while but I haven't installed it yet. Haven't been driving much in the last few months but will probably install it soon.
Received 2,093 Likes
I also did the ashtray. (You can also get a set of trim removal tools for about $8...maybe less at Harbor Freight).
The front lip we installed was much harder than this, and this really makes a difference in the way the car feels!!
Not So Fast (01-27-2016)
https://www.corvetteforum.com/forums...ing-in-c6.html
