Headlights crazed already...thinking of tinting.
Hey everyone,
I just bought my 2007 with the headlights crazed and cloudy inside already. My question is do you think I could make it look better with tint like headlight armor or have a shop spray tint them?
They look terrible and I want to try to improve the look without breaking the bank buying new units.
Before some of you reply that tint crazes the lights, remember mine are already fugged so Im not worried about it.
I dont want a dark tint, maybe just 50% or so,
has anyone out there done this and do you guys think a light tint will look good with a black car ?
I saw pics of completely blacked out lights on a black car and do not like it at all.
Opinions, advice welcomed.
Race Car Tech
IMO, it's best just to buy new lenses for it and get it over with. Save your pennies until you get new ones.
Tinting will not mask the crazing, and likely will not look any better with the tint on them. I know in some jurisdiction, it's illegal to tint headlights.
You can get new lenses for $400.00 a pair or less. It is easy to remove the old ones and install new lenses. Lot's of help, PDF's, video's etc are available from numerous C6 forum members if you go that route.
Good Luck with whatever you decide.
Check your local laws first. Around here you can't get a state inspection with any kind of tint on them. My 07 lenses were o.k. when I bought the car so i just put a clear bra over the lenses to protect them. I may paint the inside from silver to black later. I believe you can just replace the lens and not the whole assembly for about $200.00.
I had the same problem. In fact, whatever the prior owner tried made them horrible!
I did not want to spend >$400 PLUS doing the oven/r&r routine for a car in great shape that will never be a show car. But, if need be, I'm ready to go there.
Anyway, Lamin-x "tint" is said to let 85% of the light through, and the fitted film cost only $59, so I felt it worth a shot. Turns out, the install was very tough so I had a pro do it for $75.
I am very happy with the result. It does NOT eliminate the problems. It greatly mitigates them however. Kinda a 5-footer at this point instead of a 20-footer. The lighting at night is now "C5" quality instead of "C6" quality, which is fine for my purposes. It passed recent inspection. For now, I'm not even remotely considering replacing the lenses...
This picture shows the "after." Too bad I do not have a "before," but the improvement is significant IMO...
NSF
"Gunsmoke" is one shade darker. I think it lets a bit less than 80% of th light through. I used it on my taillights -- where seeing them, and especially the brake lights, is more important than what I can see in front of me. I've had people follow me day and night and they're OK with them...
I read the detailed instructions and would have tried the "correct" procedure had the result been terrible.
Not perfect, but good enough for my purposes...
I actually had my headlights restored at Sam's Club for $25 2 years ago. They bake on a new UV coating and warranty for 5 years. You can still see crazing when the lights are on, but they look fine in daylight. Well worth $25.
Try this: minimum $300 savings AND a bunch of labor that, knowing me, would be far from 100% likely to be lsuccessful...
I probably wont install mine because I had second thoughts, another poor buying decision before I thought it thru I also got the fog light film but had them in yellow already
NSF
If you decide to get new lenses, Rlsebring is the man on the forum to get them from. I just ordered another set from him recently and he is running out as his source is no longer going to supply the oem lenses, so get them soon. It's much cheaper than buying the whole assemblies and most of the lenses you see for sale are not oem. Just a little fyi. Good luck on your decision.
Rapid Fred (02-03-2016)
I was thinking of doing this but heard that the tint makes the bulbs hotter than they already are and causes them to burn out or damage the lenses. Im not saying this will happen. Just something I read a while ago.
Unless someone has IR temp readings and proof showing that true.. It sounds ridiculous.. I don't see the tint being able to block any long wave radiation from the bulbs or enough tht it would affect cooling... Maybe if you tinted the headlights with one of those reflective space blankets... Lol...
Looks cool
NSF
