Driveway destroying CF splitter
My driveway is steep at the street and the street is angled. I have to make right turns only into and out of the driveway. If I turn left into it I scrape the splitter bad.
We moved into our current home in 2001, and I built a "ramp" at the gutter as several others in the subdivision had done. I angled the leading edge towards the street to direct rainwater and it works great for me. The ZR1 style splitter on my GS does not scrape, but the under bumper valance rubber panels still barely touch.
A few neighbors have the BRIDJIT.
right there with ya
Hey guys,I have a Grand Sport that I have installed a carbon fiber splitter on,backing out the splitter scrape on the driveway and tears out chunks, I have purchased a new one but need to find a way to keep this one from being destroyed ,anyone have success in using the fat daddy's on the skid rails ? Any ideas?
I have a front splitter and side skirts on mine. There done in a Hydrocarbon finish. The trick I learned from Pat from American Hydrocarbon is to install door guard molding around the bottom. Can't tell it is an add on, Looks like it is part of the splitter and side skirts. When the molding gets scratched up you just pull it off and replace it. An 18 foot roll is like 12 bucks.
[IMG]https://cimg5.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/2000x893/80-
Not the best picture but you get the idea
This is exactly why I wouldn't do carbon fiber splitter or side skirts, they look great but cost way to much money to be putting that close to the ground. if not the curb the rock chips will kill it.
Same with the side skirts. The shape of them makes the lowering less than 1/2" lower than just the rocker panel. I have no issue with speed bumps but I do roll gently over them. It's seems like most folks don't slow down for them and often see speed bumps gouged out by radiator supports.
As for getting them chipped up, I Xpelled them and have not a nick. Now if I lived in an area with many deep pothole or gravel roads, I would have thought hard about installing them.
#33
I can't put a carbon fiber splitter on my car where I live. A Bridjit won't help me either due to the slope of my driveway. The drain passageways between streets still scrape even on approched angles. People get mad at me when I slow down for this. I have to rely on rollers installed in front of the plastic air dam to roll and lift the car enough to get up the slope. The air dam is considered a sacrificial lamb that scrapes every time. i also mounted skids under the rocker panels to protect them. Maybe someday a coil over air system will get installed. Pricey though.
