Check Engine w/ Vitesse Throttle Controller & JDM Throttle Body
This email is more of a cautionary tale for anyone making these mods. I installed the Vitesse Throttle Controller a little over a month ago and it has worked great this whole time no complaints. I decided that I wanted to put a new VMAX ported throttle body on from JD Motorsports which arrived this past Friday. It was a super easy install for the throttle body and like I do after every time I work on my cars I took it for a quick test drive after and all was fine in the 1-2 mile drive. Fast forward to this morning after the car sat in the garage all weekend. I jumped in the car and fired it up pulled out and left for work 2 or 3 miles into my drive it felt like threw an anchor out the back and the check engine light came one. I was also getting the DIC message about the need to service the traction control system blah blah reduced power.
I limped back home and checked the car and forums real quick and checked some normal items all were fine. A couple of restarts and the message was still there. Then I saw the post in the Vitesse install thread that someone got the same error message when it wasn't installed correctly. I know this wasn't my issue since it's been working properly for a little while now. Then the light bulb clicked on, it's a new throttle body and the Vitesse needed to be calibrated to my old one before using it last time. So I re-calibrated it and fired up the car an viola no more DIC message and the car seemed normal. The check engine light is still on after 10 miles or so but I'm guessing that will turn itself off soon.
The moral of the story is don't do like I did and install the throttle body after your Vitesse Throttle Controller and forget to re-calibrate it this way you can save some headache.
Steve
Steve
The following 2 users liked this post by LCSteve:
09_BSM_Z51 (03-21-2016),
Red Devil (03-21-2016)
Good catch, thanks for the heads up. I installed a VMAX tb weekend before last and got a vitesse coming in this week. If you have a handheld tuner, you can delete the trouble code so no more check engine light.
Enjoy your combo when the controller comes in this week. Going from Eco-0 to SP-5 is followed by
I installed a full new throttle body vs the spacer and I can't say that I really notice that much of a difference in the seat o pants dyno. I wasn't really expecting much of a difference though as 6-9 HP can be almost impossible to detect especially when you are starting with so much to begin with. I'm more hoping that the extra 1-1.5mpg is more noticeable
