Inexpensive mod that will put a smile in your face
Old 04-07-2016, 08:20 PM
  #121
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
Got my order in from fabric gurus today. I ordered red, and my car is Crystal Red Metallic. It's a pretty good match in color so will work ... obviously doesn't have the sparkle of CRM but I don't think you'd want something like that.
I haven't installed it yet because I want to take my time doing it, but I cut off a small, maybe 3 inch, piece and stuck it in the seam. It goes in fairly easily and will not fall out ... adhesive is not needed. What appears to be "barbs" in the picture are just slits, presumably so you can turn corners easier. I haven't decided if I'll try to make the 90 degree turn on the door opening (the part that goes into the door jamb when the door is closed) or just cut it off flush. Making the turn would require a little surgery on the bead itself. The bead has red plastic around a white round stiff piece of plastic.
It looks like pretty good quality for the price. I'll decide whether I like it once I get it installed. If not, it's just a $12 mistake (counting shipping).
Old 04-07-2016, 08:27 PM
  #122
Patsgarage
Patsgarage's Avatar
Received 1,596 Likes on 1,074 Posts
I got some from the OP's link, they have a local store so I was able to match the color exactly. I used a plastic trim tool to push it into the gap, which worked great. Best $4.26 I have ever spent.
Old 04-07-2016, 09:08 PM
  #123
Not So Fast
Not So Fast's Avatar
Waiting for mine, should ne here tomorrow. I have the other stuff but it requires adhesion so I don't want to do that, hopefully as you said, it stays by itself. If not then the whole thing is a mistake and will cost less than $25 for both, I've made bigger ones
NSF
Old 04-07-2016, 09:18 PM
  #124
Husker C6
Husker C6's Avatar
Put mine in tonight. I used the 1/8" from fabricguru and it was almost too wide for my car. No way is it going to go in front of the passenger grab handle. I think I like it but am still undecided. I will leave it for awhile and see what I think.
Old 04-07-2016, 10:33 PM
  #125
gwyliecoyote
gwyliecoyote's Avatar
Press in or adhesive? Looks great!
Old 04-07-2016, 10:39 PM
  #126
Husker C6
Husker C6's Avatar
Just pressed in. It's not going anywhere unless I pull it out.
Old 04-08-2016, 12:32 AM
  #127
Grimlock13
Grimlock13's Avatar
How much of it did you buy for enough to do both doors?
Old 04-08-2016, 05:55 AM
  #128
Patsgarage
Patsgarage's Avatar
I used the OP's link and did both doors and a line over the tweeters with 2 1/2 yards, and had maybe 6" left over. So figure with 7'-8' you should be good.
Grimlock13 (04-08-2016)
Old 04-08-2016, 06:07 AM
  #129
Husker C6
Husker C6's Avatar
I ordered 4 yards and have several feet left over. 8 feet should be plenty.
Old 04-08-2016, 07:00 AM
  #130
Grimlock13
Grimlock13's Avatar
Now I have to decide between the Pacific Blue or Pearl Gray for a Night Race Blue with ebony interior car.
I think the darker gray will not be seen really with the black door panels.
Old 04-08-2016, 07:51 AM
  #131
C6ToGo
C6ToGo's Avatar
Received 1,116 Likes on 693 Posts
Originally Posted by RadarP3C
I just want to confirm that the excess did not leave any marks on the plastic door panel after you rolled off the excess.
Nope. Rubber cement dries quickly and leaves no residue when you remove it. Use a toothpick to remove any left in the gaps.
RadarP3C (04-08-2016)
Old 04-08-2016, 09:58 AM
  #132
C5-1
C5-1's Avatar
Looks Great. I had the same issue with the passenger side, but what seemed to work was placing my knee on the door to keep it in place and with one hand lift up the door grab handle while at the same time pushing in the piping
Husker C6 (04-08-2016)
Old 04-08-2016, 12:11 PM
  #133
Not So Fast
That sure is a lot thicker than the vinyl type !!!
NSF
Old 04-08-2016, 12:21 PM
  #134
Husker C6
Husker C6's Avatar
Thanks, I think I will get someone to help and see if I can get it in there.
Old 04-08-2016, 07:15 PM
  #135
jay c smith
jay c smith's Avatar
Default Door Panel
This is my {expensive} door panel modification, but I think it was worth it.
Old 04-08-2016, 11:21 PM
  #136
1rusty1
1rusty1's Avatar
Originally Posted by jay c smith
Attachment 47970728
Yeah. That's all together a different mod. Looks good. DVS?
Old 04-09-2016, 09:46 AM
  #137
jay c smith
yes! dsv
To Inexpensive mod that will put a smile in your face
Old 04-09-2016, 05:28 PM
  #138
Not So Fast
Got mine from faricguru today, but as Husker said its pretty thick. I just don't think it fits for me so its a no go Oh well I'll give it a pass
NSF
Old 04-09-2016, 05:36 PM
  #139
Husker C6
Husker C6's Avatar
Got my last piece in today. I do like the little bit of color it adds to the inside. Probably the least expensive mod I have ever done.
Old 04-10-2016, 05:17 AM
  #140
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
NSF
I haven't put mine in yet ... been too cold in the eastern part of the country to fool with. I'll try it, and it it's too big (i.e., gaudy) I'll just remove it and throw it in the recycle bin.
Quick Reply: Inexpensive mod that will put a smile in your face
