Clay bar vs compound
Old 04-21-2016, 08:11 AM
DDP
DDP's Avatar
Default Clay bar vs compound
I think it's time to freshen up the look of my black Vette, the question is is it better to clay bar and wax or compound and wax? The paint is in good shape except for some stone chips.
Old 04-21-2016, 08:19 AM
jimmie jam
jimmie jam's Avatar
Clay will REMOVE what compound will not. Check out www.autopia.org for some help....
DDP (04-21-2016)
PacificaVette
PacificaVette's Avatar
Default Compound vs Clay
You might want to post this in the Car Care Discussion section. That's where the serious detailers hang out. You'll generate a lot more replies, and get some pretty good advice over there. That said, I think you you should use clay first. It removes impurities from your paint and gives you a clean surface for polishing.
The following 2 users liked this post by PacificaVette:
DDP (04-21-2016), I Fly Low (04-22-2016)
Old 04-21-2016, 08:21 AM
KyJim
KyJim's Avatar
Put you hand in a baggie and gently rub across your paint. If you feel any roughness it needs to be clayed. I clay mine once a year and follow up with 2 coats of Pinnacle wax. I have no swirls or scratches on my car.
If your finish does not have much contamination, use very fine clay. I use the Pinnacle ultra fine clay bars.
Yaupon (04-21-2016)
Old 04-21-2016, 08:22 AM
DDP
DDP's Avatar
This is the compound I used on my C4 which turned out pretty good, never used clay bar before so I'm a little nervous about that.
Old 04-21-2016, 08:25 AM
DDP
DDP's Avatar
Yes I did the Baggie thing and it's not smooth. I guess I'll try the clay bar.
Your car looks great did you just do the top of the car or down the doors and fenders as well?
Old 04-21-2016, 08:50 AM
Don-Vette
Don-Vette's Avatar
You can't mess up with clay bar just keep area wet.
DDP (04-21-2016)
Old 04-21-2016, 08:52 AM
extrapilot
extrapilot's Avatar
You should clay when ever prepping for polishing and waxing.
Using clay is real easy, just need to keep the clay wet and use a good lubricant, detail spray will work fine in most cases. Keep kneading the clay to keep a clean surface up. Flatten the clay with your hand and use a back and forth motion. Once the clay stops grabbing up the contaminates, move on to a new area. Run your hand across the surface and feel how smooth the finish is. Your done at this point.
Old 04-21-2016, 08:53 AM
Sabre34
Moderator
Support Corvetteforum!
Sabre34's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I clay bar about once a year and either wax or quick detail spray in between.
Old 04-21-2016, 08:54 AM
jimmie jam
jimmie jam's Avatar
AND, remember you do not apply any pressure...just let it "glide" over the surface. 2 X 2ft area or small panel at a time...like Don says KEEP WET.
Old 04-21-2016, 08:56 AM
KyJim
KyJim's Avatar
DDP, the Meguiar's Ultimate compound is for use after you clay. It's somewhat aggressive and I don't use. I do the whole car except for the acrylic top panel. I clean this only with Stoner Invisible Glass. Start at the upper surfaces and work down.
Use fine clay (Griots, NP, Pinnacle, Mothers, Meguiar's) are all ok.
Use a detail spray, I use Mequiars Last Touch Detail spray diluted with about 30% distilled water, as a lubricant. I cut the clay bars in thirds. Rub with very light pressure side to side and front to back (not in circular patterns) and use plenty of lubricant. You will be able to tell when the surface is clean as the clay will freely glide across the paint. Ball up and flatten the clay back out after each panel. You will see the contaminates on the clay.
You can use your Ultimate compound after you clay if you have some light swirls, but remember each time you do this you are removing a little bit of paint finish.
Follow up with a good wax or sealant and post some pictures as it should look good.
When we designed the Corvette Museum, I spent some time with the guys in the detail shop getting cars ready for museum delivery and they survey each panel and mark them with white chalk. These areas get clayed before they are waxed. I learned what I do from them.
The following 2 users liked this post by KyJim:
AORoads (04-22-2016), DDP (04-21-2016)
Old 04-21-2016, 09:09 AM
Welker1
Welker1's Avatar
Another 'vote' for clay bar. I do mine once a year, as other's have stated they do, to remove any & all the road grime you pick up over time.
Old 04-21-2016, 09:10 AM
jrose7004
jrose7004's Avatar
Received 1,675 Likes on 1,298 Posts
Clay bar is much easier to use. Pretty much fool proof.
Old 04-21-2016, 09:52 AM
Mark H
Mark H's Avatar
All you need to know when it comes to car care!
http://www.autogeek.net/
The following 2 users liked this post by Mark H:
DDP (04-21-2016), RaceNH (04-21-2016)
Old 04-21-2016, 10:17 AM
cmonkey713
cmonkey713's Avatar
Received 1,251 Likes on 916 Posts
Clay first and see what you are dealing with. Paint correction is a serious project especially icy are not skilled the art. Go to the Autogeek website and view their videos on paint correction before you touch the painted surface with an abrasive produce. Proper buffers, pads and products is a must for a successful outcome. If you are in doubt of your skills take it to a good detailer that is familiar with the Corvette clear coat.
DDP (04-21-2016)
Old 04-21-2016, 10:42 AM
windyC6
windyC6's Avatar
Something just doesn't seem right about dragging a piece of clay across your paint to pick up road "debris" and then dragging said clay across the paint with the collected debris in it. As Mr. Spock would say...."its just not logical".
Old 04-21-2016, 10:53 AM
Mr.Nubain
Mr.Nubain's Avatar
Location: If you wanna live life on your own terms, you gotta be willing to crash and burn Florida
I've always used clay bars, on my fun cars. Nearly 20 years of detailing and I've never had a bad experience with them. I've always used the Meguiar's clay and detail spray to do it and the results have always been great and Meguiar's is affordable too. I clay before I put her in storage and maybe once in the middle of the summer just because I enjoy the whole clay/polish/wax look when it's done.
DDP (04-21-2016)
To Clay bar vs compound
Old 04-21-2016, 10:57 AM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,843 Likes on 1,801 Posts
The one thing I did not see mentioned here is that if you drop your clay, throw it away. It will pick up tiny rocks and other debris that will scratch the crap out of your paint.
The following 2 users liked this post by Corvette_Ed:
DDP (04-21-2016), Mr.Nubain (04-21-2016)
Old 04-21-2016, 11:09 AM
Mr.Nubain
Mr.Nubain's Avatar
Yup, toss it. Damaged good. That can really f up your paint and your day if one re-uses. Clay is pretty cheap to replace, paint isn't.
Old 04-21-2016, 11:10 AM
NashvilleGrandSport
NashvilleGrandSport's Avatar
I use Meguiars Ultimate clay with their spray detailer , polish and wax. Easily done. Very pleased with the results.
Quick Reply: Clay bar vs compound
