Wheel Color Identification
I'm both a new Corvette owner and new to this forum so I come seeking advice from the experts...probably for the first of many times. I've already perused some of the threads and it appears this is an amazing resource that's supported by years of experience from gracious fellow 'Vette owners.
My 2008 C6 has a small scrape on the edge of the wheel that I would like to touch-up with the correct paint color. I've reviewed the "2008 Corvette Color Compatibility Guide" that someone graciously compiled and posted to this forum. With this guide I've narrowed it down to three options:
I've reviewed the original build sheets that I was given and I was able to identify the Victory Red exterior spec, but I can't locate a code or spec that would reference my wheel color.
Is there a way to identify the color code so that I'm not taking a 50/50 guess at one of the Silver color codes above?
Thanks in advance for any advice you can provide.
- Silver / WA837K
- Silver / WA8867
- Gray / WA9243
I'm not sure but if you could post a pic of your car I'm sure someone on here could help out! This is a great forum with lots of knowledgable people! Welcome!
If your wheels appear "chrome like" they may be polished aluminum with a clear coat and not a "painted" wheel at all?
Mine are "Comp Gray" i'm guessing this would be the gray listed above.
Tyler
Tyler
Doc_Ox (04-22-2016)
Assuming you have the stock wells that came on the car, the 2008 came with the following wheel options. Competition Gray, Chrome and Polished Aluminum. From what you say, I am betting you have the factory polished aluminum wheels. If that is correct you will need to have the wheel repaired. There are a lot of people that do this, in fact some dealers have them come to their place and repair wheels for customers.
Doc_Ox (04-22-2016)
Thanks for the quick responses. I don't have photos of the damage with me here at the office, but I was able to confirm via the window sticker that I indeed have polished aluminum wheels -- specifically "5 Spoke Aluminum Wheels" per the sticker.
The damaged area isn't too large and it's at the edge of the wheel where it meets the tire. It looks as if someone grazed a curb or it was damaged when being separated from the tire. Any rough idea how much it would cost to repair it? Given that it's only about 1" long and at the very edge of the rim it may not be worth the repair depending on the cost...and, of course, based on how much it bothers me since I "know" it's there.
My wife curbed the two wheels on the passenger side of her Caddy ATS and the cost was $140 per wheel. The damage was more extensive than what you described, but as I said ... it's probably just the fact that you're getting it repaired. Her wheels are painted with clear coat. As I recall, he said that chrome/aluminum would be $190.
It's not cheap, but I cannot tell at all that the wheels were ever damaged.
You can Google "wheel repair", or just call one of the higher end dealers in your town and see who they use. Sometimes they will come to your house to do the repair.
I had a chance to take photos of the wheel scuff last night. Like I mentioned in my original post, I don't think it's 'too bad', but of course 'I' know it's there. I've tried removing the black tarnished area as much as possible with wax/polishing compound and wheel cleaner, but most of it is still visible. In my opinion this is what catches the eye the most. Does anyone know the best method to remove this tarnish, leaving on the (scuffed) aluminum behind? If I'm still not satisfied with the results I'll look into getting it repaired per the prior recommendations above. Thanks.
Received 1,919 Likes
https://www.corvetteforum.com/forums...-up-paint.html
I think you might want light warm nickel, code WA 837K, available from several on line vendors. You might have to try a couple of different ones, though.
Race Car Tech
I just bought a used wheel from this forum, and all was good for $100.00 + $20.00 shipping.
I since replaced those with ZO6 Chrome wheels, and sold the 4 polished wheels locally shortly afterwards for $350.00.
Good luck with a touch up, or repair, or replacement.
http://www.paintscratch.com/cgi-bin/select-color.cgi
-Light Warm Nickel Effect (837K)
-Ultra Silver Metallic (8867)
-Gray Metallic (9243)
-Bright Silver Sparkle Effect (9243)
Is the Light Warm Nickel Effect the best match for polished aluminum wheels?
Thanks again.
anchito27 (10-27-2021)
Thanks for the additional advice everyone. Regarding the quoted recommendation above...I found four possible touch-up colors for a 2008 Vette on paintscratch.com:
Thanks again.
Thanks again.
Where does one find the specific color for the rims? I looked on the little tag in the glove box that has everything else and I'm not seeing anything that resembles the codes mentioned above on there.
Last edited by anchito27; 10-27-2021 at 04:29 PM. Reason: Wrote coffee instead of color
Just post a picture of your wheel and people on here will help you.
and I was just having a little fun at your expense because of your typo. I see that you corrected your post.
don’t take us too seriously.
When you have been on here as long as some us, we have to keep ourselves entertained after reading the “which tire should I buy” threads all day long.
I get it, just at the same time I want to touch up my rims while I have the car put away for the winter here in northern Utah and have no idea where to find the exact match for my rims and i don't want to put the wrong stuff on and then have to deal with that debacle.
From what I've seen so far they're not too terrible. It's on the furthest edge out where they got curb kissed a little while I was first getting used to the car and got too close to the curb in the drive thru at the bank. Dumb mistakes like that, and I tend to be really good at them at times 😂
I'll have to take a picture and put it up with my computer. My phone doesn't want to do it due to low memory even though it actually has more than half of the memory available.
