spark plug question
Old Apr 30, 2016 | 07:44 PM
mmorse's Avatar
mmorse
Default spark plug question
been awhile since I replaced spark plugs in one of my Vettes. what plug/s are people going with these days. my 08 has 65k miles and am thinking about new plugs. car runs fine just thinking from a maintenance point of view. also what is the proper gap? on another topic, are there any off the shelf injector cleaners that actually work? preferably the kind you just pour into the gas tank. having a problem believing simply pouring a solvent into the gas tank will effectively clean an injector. again, my car runs fine, just looking to keep it that way.
Old Apr 30, 2016 | 08:53 PM
09_BSM_Z51's Avatar
09_BSM_Z51
I sensed there was an issue with my stock plugs so I switched them out for NGK TR5's just the copper ones not anything fancy. My stock plugs had what looked to be oil residue on the base. Car ran a little better after the change. When I installed headers I went a half step colder to NGK TR55's copper. The plugs are easy as can be to replace so I have no issues with running copper plugs, they are cheap and will not need to be changed for 2 or 3 years. Obviously, the stock plugs are just find for stock cars or near stock. Copper plugs do give the best performance but I don't think it's more than 0.00001 hp between the two. That's a little sarcasm there btw I have no data other than what I've learned about LS performance.
AC Delco makes great, long lasting iridium plugs. There isn't anything to gain going aftermarket except peace of mind. I only run AC Delco or NGK on my cars, they have earned my trust over the years for doing their job and never having any problems with either of them.
Hope this helps.
Old Apr 30, 2016 | 09:05 PM
WW7's Avatar
WW7
To answer your question on cleaners for your engine , I use what many others on here use, "Techron fuel system cleaner" made by Chevron..I add a bottle to my tank 3 or 4 times a year...It's suppose to be the best ..WW
Old May 1, 2016 | 02:16 AM
mmorse's Avatar
mmorse
I have used that also. recently saw a YouTube video of a guy who tested a bunch of carbon cleaners for the cylinder. he made before and after images of the top of each piston using a bore camera through the spark plug hole. even after two bottles of techron, there was very little difference. gum out no better. what did show some cleaning was sea foam. he couldn't speak to valve or injector cleaning as he had no way to confirm the results.
Old May 1, 2016 | 02:19 AM
mmorse's Avatar
mmorse
Hope this helps.
on previous Vettes I used the ngk tr55s. actually replaced AC Delco iridiums with them. but that was two Vettes ago. I guess things haven't changed any regarding plugs and these cars.
Old May 1, 2016 | 08:21 AM
Mad*Max's Avatar
Mad*Max
the original plugs are good for 100k miles, my 07 plugs are at 72k and are fine, I will probably replace with OEM at around 90k
Old May 1, 2016 | 10:15 AM
CHJ In Virginia's Avatar
CHJ In Virginia
At 65 K miles with no performance problems, you are wasting your $ replacing plugs. IMHO wait till 90-95 K miles and then replace with OEM Delco Iridium and do a set of GM red performance wires at the same time. Over the years, I have found that wire deterioration causes more problems than plugs.
If you have the urge to do something, pull the plugs and put a light coating of anti-sieze on the threads. Corrosion between dissimilar metals - alum head and steel plug can make high mileage ones difficult or impossible to remove. If you get there, you are into some serious machine shop work after head removal.
Old May 1, 2016 | 02:54 PM
HOXXOH's Avatar
HOXXOH
I agree with the others to wait on plugs. Considering your average annual use, you probably will be into a different car or 2020 before you hit 100K miles.
Chevron gas already contains Techron, so using it regularly or every 3-4 tanks will keep injectors clean.
Old May 1, 2016 | 03:25 PM
cclive's Avatar
cclive
Replacing plugs now is just needless maintenance. There are other ways to interact more with the Vette than replacing things that don't need replacing, but this is a forum pet peeve of mine.
Old May 1, 2016 | 07:11 PM
mmorse's Avatar
mmorse
I just pulled a plug in each bank and they look really good. virtually no carbon build up, just a very mild light tan. both gapped at .044. guess I'll leave them alone for awhile.
Old May 1, 2016 | 07:16 PM
mmorse's Avatar
mmorse
I have put in a couple bottles of techron in the past. I use mainly Mobil which also has extra detergent in it. got a couple bottles of chemtool to add to the gas. that is supposed to be really good at cleaning injectors and valves.
To spark plug question
