What did you do to your C6 this weekend? - Page 114 - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 04-11-2018, 03:31 PM   #2261
Racer1735
CF Senior Member
Racer1735's Avatar
I did the Ranger method for my clutch as well as replaced both the front and rear emblems
Racer1735 is online now   Reply With Quote
Old 04-11-2018, 03:36 PM   #2262
Racer1735
CF Senior Member
Racer1735's Avatar
From this on the front
To this.
And the rear is now bright
After looking like this
Old 04-11-2018, 06:05 PM   #2263
Jon05vette
CF Senior Member
Support Corvetteforum!
Jon05vette's Avatar
C6 of Month Finalist 2016
Default Paint correction
spent 3 days performing paint correction and applying 3 coats of JAXWAX Cerimaic Pro 9h.
Jon05vette is offline   Reply With Quote
The Following User Says Thank You to Jon05vette For This Useful Post:
JerriVette (04-15-2018)
Old 04-11-2018, 07:10 PM   #2264
Bruze
CF Senior Member
Bruze's Avatar
Quote:
Originally Posted by Bruze View Post
Well I'm glad I didn't take the Vette to lunch today (it's still hibernating).
I wish *I* didn't go to lunch today.
I'm coming home around 1:00 in my 2017 pickup, with 6300 miles on it, and about a mile from home a deer jumps right out in front of me. I didn't get hurt at all, but her life ended very quickly.
Oh well.
The adjuster called me this morning. The original estimate was for $9,300 and pending, but it's up to $11,400 now that it's apart.
It's at my buddy's shop so I went over today to look at it. FWIW, I have Traveler's insurance and my buddy said the adjuster was absolutely great, no problems at all. He's thrown some (Allstate) out of his shop.
And my local independent agent is also great; everyone in this whole mess has been wonderful to deal with.
Bruze is online now   Reply With Quote
Old 04-12-2018, 12:28 PM   #2265
mrcopmn
CF Senior Member
mrcopmn's Avatar
While I have been waiting for the snow and rain to stop, I decided to fix my coolant leaks. My 2009 vert, with 32K miles, was dripping from the radiator petcock and I discovered that the hole was warped and not fixable and the tank seal was leaking. I ordered a DeWitts radiator. The heater hose tee was leaking and the rest of my hoses were showing signs of age. I had replaced the small return hose and tee with clamps last summer not using oem. I ordered a HPS silicone hose set. The HPS hoses have the tees molded in and are high temp and pressure rated. This eliminated the two tees and clamps.
Before upgrade. Oem molded tee was leaking at two of the connections.
DeWitts radiator during install.
Install complete. No more leaky tees and petcock.
In the past, I had installed a DeWitts radiator in my C5 and was very pleased with those results.
This install was straight forward and again I am very pleased with these results. DeWitts makes great radiators with no modifications.
mrcopmn is offline   Reply With Quote
The Following User Says Thank You to mrcopmn For This Useful Post:
jeffs64 (04-14-2018)
Old 04-12-2018, 02:16 PM   #2266
Not So Fast
CF Senior Member
Not So Fast's Avatar
How are the temps with the new rad ??
NSF
Not So Fast is offline   Reply With Quote
Old 04-12-2018, 04:03 PM   #2267
Racer1735
CF Senior Member
Racer1735's Avatar
Back by the license plate has never worked since I bought my C6 last June, so today I removed it and disassembled and cleaned it out. Now it works properly! Decided to go for a drive but when I pressed the start button, the dash only registered 11.6 volts! This after taking it out yesterday with readings of 14+ volts (and living on a better tender). These cars tend to keep you humble.
Old 04-12-2018, 05:44 PM   #2268
mrcopmn
CF Senior Member
mrcopmn's Avatar
Quote:
NSF
Unfortunately I haven't been able to take it out on the road yet this season because we keep getting snow. At idle it is running around 203-206 degrees F. It took it awhile to burp. I put a 50/50 mix of coolant in as recommended. The DeWitts adds a gallon of additional coolant capacity and double rows. My past experience is that it won't run as hot and will cool down considerably quicker when you start moving. I am guessing it will run down the highway at about 194 degrees F with the stock thermostat. Now I won't have to worry about the oem radiator crapping out or issues with the hoses. Granted my vehicle is 9 years old with 32K miles on it now but you would think the oem radiator and hoses would last longer.
Old 04-13-2018, 08:34 AM   #2269
Bruze
CF Senior Member
Bruze's Avatar
Same here, although snow is not the issue now. They salted the roads Easter weekend and it isn't gone yet.
Plus, there's mud in front of my barn that I ain't driving the Vette through; I would probably get stuck. It's usually pretty much hardened up by mid-April. Cold spring: I'm out of coal and almost out of firewood.
Old 04-14-2018, 08:00 PM   #2270
twister1442
Junior Member
twister1442's Avatar
Default New Pipes!
New Corsa axle back pipes! Love 'em!
twister1442 is offline   Reply With Quote
Old 04-14-2018, 11:25 PM   #2271
GRCTampa
CF Senior Member
GRCTampa's Avatar
Quote:
Originally Posted by Racer1735 View Post
From this on the front[/i]
To this.
Looks good, where did you source your new emblems?
GRCTampa is offline   Reply With Quote
Old 04-14-2018, 11:43 PM   #2272
jeffs64
CF Senior Member
jeffs64's Avatar
Nothing. Going to take out the bike first time since last season
jeffs64 is offline   Reply With Quote
Old 04-15-2018, 09:02 AM   #2273
GHOLD
Junior Member
GHOLD's Avatar
Quote:
Originally Posted by Welker1 View Post
Took a short cruise down a couple of our county roads after breakfast this morning. Stopped a couple times to take some new 'glamour' shots
I’ve commented on them in the past “love those matching wheels”!
GHOLD is offline   Reply With Quote
The Following User Says Thank You to GHOLD For This Useful Post:
Welker1 (04-15-2018)
Old 04-15-2018, 10:48 AM   #2274
Jancsi
Junior Member
changed the vanity mirror cover (broken tabs)
Jancsi is offline   Reply With Quote
Old 04-15-2018, 01:09 PM   #2275
Racer1735
CF Senior Member
Racer1735's Avatar
Quote:
I purchased them on eBay from Yates Performance. They are OEM and look great!
The Following User Says Thank You to Racer1735 For This Useful Post:
GRCTampa (04-15-2018)
Old 04-15-2018, 02:24 PM   #2276
RogerRamjet21
CF Senior Member
RogerRamjet21's Avatar
Installed a backup camera. There was one on the car, but the previous owner for one reason or another didn't like how it looked, so he took it off, cutting and taping the wires. So I purchased
THIS CAMERA THIS CAMERA
hoping I could find and use his wires, but prepared to run the new wires that came with the camera if needed. After taking out the rear trim piece and both passenger side tail lights, I was able to find the wires and remove the tape. The result was a bundle with three wires, power, ground and video. I hooked the new camera up and verified with a tester that power was available, but no picture on the head unit (Kenwood DDX-512 with GPS). I downloaded the manual and found the configuration information for it and did the setup steps. Boom, rear view picture pops up over whatever is on the display when you shift into reverse (M6), so at least he used the backup circuit for power. I installed heat shrink tubing, soldered the connections and shrank the tubing. The only other thing I did was to install a rubber grommet in the hole he ran the wires through to prevent possible chafing. So happy to have a backup camera, especially at night as the tint on the windows is darker than I might have opted for.
I may opt for one of the really small cameras in the future, but this license plate mounted unit is okay for now (Note: I've tucked the wire leading into the body better than this shot shows).
Last edited by RogerRamjet21; 04-15-2018 at 05:11 PM. Reason: Additional information
RogerRamjet21 is online now   Reply With Quote
Old 04-15-2018, 02:39 PM   #2277
MYCoupe
CF Senior Member
MYCoupe's Avatar
Got around to installing my used Caravaggio steering wheel
MYCoupe is offline   Reply With Quote
The Following User Says Thank You to MYCoupe For This Useful Post:
Old 04-15-2018, 02:46 PM   #2278
Corvette_Ed
CF Senior Member
Corvette_Ed's Avatar
Nothing for yet another weekend. Was in the 70s all week long, and woke up Saturday morning to 38 degrees. It wasn't much warmer today.
Corvette_Ed is offline   Reply With Quote
Old 04-15-2018, 02:52 PM   #2279
Welker1
CF Senior Member
Welker1's Avatar
Weather has been great here. Drove it down to Vegas to pickup my youngest granddaughter. Took the top off yesterday and took her for a little cruise around town and down some of our back roads. She had a blast and loved it; she got a kick out of putting her hands up and letting the wind hit them, laughed and had a big grin on her face the whole time
Welker1 is offline   Reply With Quote
Old 04-15-2018, 05:11 PM   #2280
JerriVette
CF Senior Member
JerriVette's Avatar
Had my GM world class tech install a new harmonic balancer from summit racing. The 120k mile c6 z51 m6 that I've owned since new runs smoother than ever!
Who would have ever thought swapping out a harmonic balancer would allow the vehicles engine rev even smoother than ever..
I'm really glad I did the harmonic balancer swap...
I wonder if a harmonic balancer out of kilter could have at times caused the engine to pull timing because driving since the swap seems much better
JerriVette is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • What did you do to your C6 this weekend?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    2018 Carbon 65 edition 99FewteRC5 C7 General Discussion 21 01-27-2018 03:19 PM
    FS: NEW C7 Logo embroidered Under Armour zipper hoodie! XXL joeybsyc C7 Parts for Sale/Wanted 4 11-28-2017 09:00 PM
    FS: Cobra Race seat. High end Kevlar and carbon fiber bruce1 Autocrossing & Roadracing Classifieds 4 08-10-2017 11:45 AM
    2017 red paddle install CSEVEN C7 General Discussion 31 06-19-2017 12:38 PM
    Let the shows begin !!! Mistrezz 06 C5 General 19 05-02-2017 12:03 AM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    Sponsored Ads
    Vendor Directory
    • Ask a Question
    Question Title:
    Description:
