What did you do to your C6 this weekend?
Old 05-18-2019, 10:47 PM
  #3341
Narddog
CF Senior Member
Narddog's Avatar
Originally Posted by roseykr View Post
Contact cement . Worked great, never coming loose.
Did you notice buttons / vents / things not working as smoothly as they used to? ex: the hazard button or the TCS button.
Narddog is offline
Old 05-19-2019, 07:28 PM
  #3342
Welker1
CF Senior Member
Welker1's Avatar
Did something small and relatively easy, but got rid of an irritation. I didn't like having to leave the ashtray door open when I plugged in my phone charger; also didn't like the cable just flopping over the center console. So, today I decided to do something about it and ran the cable down, inside the console, and pulled just enough through where plastic trim meets the carpet to come up to where it plugs into my phone. Sometimes it's just the little things ..
Welker1 is offline
Old 05-20-2019, 12:33 AM
  #3343
roseykr
Junior Member
roseykr's Avatar
No real issues to speak of. The top vents don't travel as far up/down as they did prior to the install, but they still move enough to get the job done well. The traction control button was worrisome at first, but after playing around with it a bit, it works just as it did prior.
roseykr is offline
Old 05-20-2019, 09:00 AM
  #3344
southofHoustonVette
CF Senior Member
Like the carbon fiber shifter ****.
southofHoustonVette is offline
Old 05-20-2019, 11:57 AM
  #3345
OregonMike
CF Senior Member
OregonMike's Avatar
Got the front & rear sway bar end links installed. Took care of most of the suspension clunks I was hearing.
Got new rear tires installed. Sanded/polished/ceramic coated the wheels while I had them off.
Painted the calipers while I had the wheels off.
Had the passenger side exhaust/muffler out attempting to replace with a more open flow muffler but the ones I ended up with are too long to fit. Put the old pipe back in. I did drill the pipe for the muffle mod while I had it out. Will drill the driver's side later.
Changed the oil.
New tires need some scrub in time...spun a bit just pulling out of the driveway without even trying!
OregonMike is offline
Old 05-20-2019, 12:47 PM
  #3346
Joey D
CF Senior Member
Started installing carbon fiber front splitter.....mud guards in the rear are next
Joey D is offline
The following 2 users liked this post by Joey D:
centennialGS (05-29-2019), jimijam (05-20-2019)
Old 05-20-2019, 12:55 PM
  #3347
C6 Snowboarder
CF Senior Member
C6 Snowboarder's Avatar
Glad none of you guys did this to your C6 this weekend. Looks like it took only about a day.
C6 Snowboarder is offline
Old 05-20-2019, 01:47 PM
  #3348
Welker1
CF Senior Member
Welker1's Avatar
Thanks; had a little wrap left over from another project and decided to put it to good use.
Welker1 is offline
Old 05-20-2019, 01:52 PM
  #3349
Huskerman
CF Senior Member
Support Corvetteforum!
Huskerman's Avatar
I put some new shoes on baby this weekend........ I like em.......
Before......
....and after......
I also put on that front splitter a couple of weeks ago..........
Huskerman is offline
Old 05-21-2019, 03:11 PM
  #3350
southofHoustonVette
CF Senior Member
Before......
....and after......
Runs looks sick man. Good pick
Huskerman (05-21-2019)
Old 05-29-2019, 12:56 AM
  #3351
Eritosthenes
CF Senior Member
Eritosthenes's Avatar
I replaced the hatch release button just above the license plate. I'd gotten it to work once before by taking it apart and washing out all of the fine accumulated silt. This time I had to replace it with a new one (about $11 on Amazon). It's nice not having to dig out my key fob every time I want to put something in the trunk.
Eritosthenes is offline
Old 05-29-2019, 01:59 AM
  #3352
HOXXOH
CF Senior Member
HOXXOH's Avatar
Prepped for a converter change this week. Hope to finish before the heat hits Phoenix.
HOXXOH is offline
Old 05-29-2019, 03:59 AM
  #3353
Telepierre
CF Senior Member
Telepierre's Avatar
I remember this been quite the balancing job for one person. Well done and if you don't mind me asking, is the converter change for drag or something else? Thanks
Telepierre is offline
Old 05-29-2019, 07:21 AM
  #3354
agorena123
CF Member
agorena123's Avatar
Picked up my first Corvette this past Friday, washed and cleaned, new battery, and order new tires on Saturday - Michelin PS 4S.
agorena123 is offline
The following 2 users liked this post by agorena123:
JerriVette (05-29-2019), Telepierre (05-29-2019)
Old 05-29-2019, 08:26 AM
  #3355
GS057
CF Senior Member
GS057's Avatar
2018 C6 of Year Finalist
Installed the Prospeed spal fan set up and Z06 Z07 package aluminum radiator. Now my water temps are 185 to 190 with AC on and 92 degrees out. Can not wait to see how they perform when it is 100 degrees out. Keeping my fingers crossed not to see an more 230 water temp when cruising at 75 mph with ac and 100 degree out.
GS057 is offline
Old 05-29-2019, 08:34 AM
  #3356
captain vette
CF Senior Member
I make a nice road trip to the thousands islands
captain vette is offline
Old 05-29-2019, 09:19 AM
  #3357
Mike Green9
CF Senior Member
Mike Green9's Avatar
Hey captain vette. Thousand Islands is indeed beautiful. I live on the Eastern end of the Thousand Island Parkway.
I was born in Mtl. Used to do the OJ on Wednesdays.
What part of Mtl are you from?
Too bad for all this rain.
M.....
Mike Green9 is offline
Old 05-29-2019, 10:09 AM
  #3358
dr_gallup
CF Senior Member
dr_gallup's Avatar
I got new Michelin Pilot Sport 4 S tires on my GS a couple of weeks ago but didn't get to really drive them in the mountains until last Sunday. Beautiful drive through Lake Lure and on up to Mt. Michel, the highest point east of the Mississippi.
dr_gallup is offline
Old 05-29-2019, 11:14 AM
  #3359
hmmmm16417
CF Senior Member
hmmmm16417's Avatar
New wheels and emblem overlays
hmmmm16417 is offline
Old 05-29-2019, 11:57 AM
  #3360
alec427
CF Member
alec427's Avatar
Cleaned up and took some pics
alec427 is offline
Quick Reply: What did you do to your C6 this weekend?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
