Harmonic balancer ringing noise on startup - cause?
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
I know it's cuz it's a POS GM balancer and many of them eventually fail by the outer ring slipping at the bond with the inner hub.
But I'm curious as to what specifically makes the ringing noise on cold startup. Is it a slight belt misalignment? There is no visible wobble (well, at least to my crappy 58 y.o. Eyes) and the noise goes away after about 10 seconds...............
If you don't have a noticable amount of wobble and your getting noise , it's probably one of 3 pulleys on the motor that is in need of grease...I had a squeal at startup that lasted about a minite or less and it turned out to be the top idler pulley was void of grease..Repacked the bearings and the noise was gone...Get a stethoscope and see if you can't pinpoint the pulley that's making the noise..WW
very few of them failed for that reason and was pretty much 2005 only, the majority of the rest of them where changed by owners listening to other owners who didn't have a clue as to what a HB does or how it operates, a stock HB on ANY makes of car DOES NOT run straight and true and only looks worse over time, ATI became millionaires off the uninformed
And where do you get off saying any make does not run true , I have had may cars and boats from small blocks to twin supercharged fat blocks and I never , never saw a harmonic balancer on any of them wobble
Yet in my two years in the corvette comunity I have seen more bad harmonic balancers than in my whole automotive career
Dave
CI 1-4-5-8-9-10 Vet
If you don't have a noticable amount of wobble and your getting noise , it's probably one of the 3 pulleys on the motor that is in need of grease...I had a squeal at startup that lasted about a minite or less and it turned out to be the top idler pulley was void of grease..Repacked the bearings and the noise was gone...Get a stethoscope and see if you can't pinpoint the pulley that's making the noise..WW
CI 1-4-5-8-9-10 Vet
Really , you going to tell me my 2011 did not have a bad balancer ... it was wobbling so bad that when the service writer looked at it his exact words were " boy that's not good"
Dave
Dave
The only difference is that we didn't have the internet so everyone thought theirs was a unique failure.
I think it's unacceptable to have such a design. However, I wonder how many people know that it's nothing new. Even with old school SBC (and the keyed crank & balancer) it was not uncommon to have the balancer separate. The outer disk moves toward the engine and eventually cuts into the timing chain cover. I've replaced many of them.
But the design on the LS motors is by far the worse ......
And you are right , the Internet helps .....
need-for-speed (07-09-2016)
people are so far out to lunch on this, how many c6 s were sold ? how many had a make believe bad balancer ? 1 % maybe. people have one issue and it is the end of the world, between this balancer and the 427 s valves, unbelievable. some folks will fall for anything, oh i need a new balacner it will destroy my engine, lol.. too funny
Yes, they can all be repacked with a high speed high temp grease.. The 3 pulleys I repacked were the top idler pulley, the AC idler pully, and the small metel covered drum pulley next to the crank pulley...On all three of these you can pull the side covers off to get to the bearings.. I use a small pick tool to get the side covers off..Then you just flush them with brake cleaner , let them dry or blow them dry with compressed air, then repack them with grease and reinstall the side covers...You can get these pulleys new ,but as long as the bearings are ok repacking them is fine......WW
At the risk of starting another whacky 136 post thread on "planned obsolescence", these bearings are woefully under lubed in manufacturing.
WW7 (07-10-2016)
If you don't think it's the pulley bearings causing the noise, you can try installing a Gatorback serpentine belt instead of the stock belt..These belts have solved quite a few high pitched squeals in these cars when the owners can't get anything else to work...WW
need-for-speed (07-10-2016)
But a genius like yourself, that has suppossedly building high-performance Chevrolets for a couple of years would know what the ringing noise is. Actually that ringing noise is between your ears probably
