Aerospace 303 Whats it good for?
After seeing people using this stuff I just picked up a bottle to try on the interior. Before I start whats it good on and what should I avoid?
Received 2,887 Likes
Use it like Armor All. It has UV protection and is a little less greasy. My favorite use for it was the outside trim for the side windows. Did not care for the look on the interior.
Use on every plastic trim including as a tire shine, all rubber weather seal around the windows and roof, but not on interior. It streaks on interior plastic. I even use it on any rubber or plastic in engine compartment and underneath including all hoses and even drive shaft and front boots. It keeps all that supple.
peter pan (07-17-2016)
I'm going to go against the grain here and say I really like the way it looks in the interior. It doesn't leave any sort of shine at all, just clean panels.
In the past I've gone with Cockpit Plus for the interior and its looked great. However, in my Vette it makes the panels look dry and almost chalky. I tried the 303 on a door panel and liked the low shine but dark result.
Received 4,712 Likes
303 is a really good product, I have used it on my fiberglass boats for years, both the hull & vinyl interior, it uses on a car would be the tires, any rubber moldings, & any exterior /interior trim panels, I would not use it on leather seats. 303 has excellent UV protection for the mentioned uses, 303 needs to be wiped on & wiped off, you can not
spray on & leave it, it must be wiped off completely
carl3989 (07-18-2016)
