100 octane at a local 76 station but,
it's $7.859 a gallon! That's a helluva fill up. The pump reads: Racing gasoline, not a Union 76 product. Wonder if a gallon or two might be worth a try in the vert the next time I'm on empty... or the STSV? Wonder which bike would show more of a difference, my six carbed CBX or the Busa?
Received 1,673 Likes
Your car isn't tuned for 100 octane gasoline. I wouldn't think that a gallon or two would be beneficial.
bucwheat (08-23-2016)
it may also contain lead and ruin your cats
At what octane is there the law of diminishing returns?
On a side note, I was at the Motorsport Ranch in Cresson, Tx a while back and snapped a photo of the fuel pump. 100 Octane is $9.64 a gallon.
They have 109 Octane unleaded and 110 Leaded also!
Received 2,681 Likes
2018 C6 of Year Finalist
OP, I don't know if you're joking or if you know nothing about gasoline.
Received 1,136 Likes
Unless the laws of physics have changed in recent decades, high octane gas burns slower than lower octane, thus preventing detonation in high compression engines, or in engines with poor combustion chamber design, allowing poor flame travel.
Simple answer: The benefit stops at the point where there is no longer detonation in the cylinder. After the knocking stops, any extra octane rating is needless and a waste of money. Octane rating does not equal horsepower.
Ah yes....the good ol days. Just keep turning that distributor till she knocks....then back it off just a C-hair.....
Timing advance and Gasoline
A little bit of background about the timing advance mapping in modern ECM programming. All modern vehicles have a top potential timing advance number programmed into the ECM. That number is a goal for the engine to reach. It's usually a lofty goal at that. Under most driving conditions the ECM continues to advance engine timing until the knock sensor starts to hear the detonation of too much advance then backs out the timing. The ECM does this constantly while you drive, This is the reason you can run any gas in any car. They have no "sack" with 87 octane....but they run. Theoretically if you have 100 octane fuel you would allow your ECM to run as much advance as your knock sensor would allow. More advance more power to a point...then they all detonate. Try the 100 Octane just for ***** and Giggles and see how she lights up those rear meats!!
I stopped at a Mobil station here this week and 87 was $1.99 and 93 was $3.09. For a fill up that is $15 more so how well does octane booster work and is that an option? It can't cost $15. The top tier stations are really sticking it to us for premium.
a good tune will allow more timing as long as there is no detonation
Dave
I drive a Vette ..... I use 93 .... lol
There is no timing range built into the factory program that is unlimited. Since 93 octane is the maximum commercial industry standard, 93 is a good number to bet on. Beyond just considering timing and octane range as it relates to producing more power is the fixed component of compression ratio. Since you cannot easily adjust compression ratio, an experiment trying the 100 octane is pretty much a waste of time and money.
I said it was a lofty goal not an unlimited number. It's usually more than the engine (operating on pump gas) could handle. The assertion, earlier in this thread, that it will damage your engine was just not true. So if you want to throw away some extra bucks and see how it runs...why not?
