Another Mild to Wild Post
When I got this car both flappers were open.
I finally got mine to close the flappers by replacing the fuse that the previous owner had pulled and reattaching a vacuum hose that was pulled off of one flapper.
I now have a mild to wild setup with remotes and it will not work! I pulled it back off and left the fuse out and the flappers remained closed!
I thought that pulling the fuse would open them up?
Does anyone have the circuit layout for this system?
I drove the car on the highway today and with the fuse out 3500 RPM did not open! With the fuse in 3500 RPM did not open! As I mentioned, when I got the car both flappers were open and would not close but there was no fuse and there was a vacuum line off of one of the flappers. As soon as I hooked up the vacuum line both flappers closed. I ordered the Mild to Wild and it will not activate the flappers. There is a link in the next response that I will study this week.
I don't have the circuit diagrams. Post 9 in here gives the SM troubleshooting process for most of the system. It might help.
https://www.corvetteforum.com/forums...post1579920143
lwise4 (08-21-2016)
But there is a compatibility issue. GM slightly changed the angle of the passenger side pipe in '09. So if your car is an '05-'08, the only NPP system that is a straight PnP swap is the '08 set. If your car is an '09+ then you would need an '09+ NPP set.
You can mix different years by also swapping the x-pipe.
I really don't know what your problem is but I know if you pull the fuse or the solenoid goes out, the open position is sort of the default. Being closed and never opening doesn't make any sense. Did you ever get a response from the M2W vendor?
The NPP circuit I believe is pretty simple. I've never actually played with it but, the vacuum I know comes from the intake manifold and goes to what I can only assume is some type of electric solenoid monitored by the computer. Once the engine hits 3500 RPM the solenoid shuts off the vacuum to the NPP valves and the baffles opens which gives you the extra rumble.
If you're fuse is connected (make sure you verify the fuse is good) and the Wild2Mild is connected properly and still not working then I would check the solenoid next.
lwise4 (08-23-2016)
lwise4 (08-23-2016)
Yes with the fuse out they are OPEN 100% of the time AKA "Wild" replacing the fuse should close the inbound pipes until you reach 3500 RPM. I remember before I removed my fuse mine would "stick" in the closed position.
I'm thinking of installing a "Mild to wild" switch soon.
Before you installed the M2W the flaps were closed and did not open. Correct? So, if there isn't vacuum at the flaps and they are closed, then the flaps are stuck. Try to move them with your hands to see if they move freely. If you have vacuum there all the time then it's the solenoid, possibly.
lwise4 (08-24-2016)
MTW Vendor
Yes I did! His response was "the installation looks good". I emailed Him this morning and asked what's next?
I ran the car up to 4000 RPM's a couple of times today and the flappers did not open! As I said when I got the car the flappers were open all of the time. The fuse was removed and a vacuum line was off of one of the flappers. I replaced the fuse and the vacuum lines and now the flappers will not open at 4000 RPM nor would they open with a mild to wild installed?
I don't think it is a good idea to remove the hose line as I am sure that is the same as a vacuum leak? Is the absence of vacuum to the flappers what opens them?
Solenoid
I have not. I just printed out the picture that another kind forum member posted. I will look at it post haste! Thanks for the reminder!
