Thanks to the CF
Thanks to the CF
2008 coupe that doesn't get driven as much as it use to and, as a result, I was getting a lot of bleed down between starts. Valve noise was significant until oil pressure was sufficient to get oil to the lifters. Then I remembered the procedure for cranking the engine without starting that was shared here in C6 Gen. Now I simply crank the motor a few times before I start it. No noise anymore as oil is replenished up top prior the starting and higher RPM's.
https://www.corvetteforum.com/forums...r-storage.html
Press and hold the throttle to the floor and press the start button. Engine will go through a cranking cycle without starting.
dr_gallup (09-01-2016)
