My street driven car doing a wheelie and a new PB - kudos to Yank and LG
Supporting Vendor
I know it's shameless self-promotion but I don't care.
With the addition of a prototype converter from Yank my car is now cutting 1.35x 60ft times like this on a pretty much regular basis at the track (this was taken last week) despite launching at only 1900RPM:
And after upgrading to 1-7/8" headers from LG (thanks to Anthony for talking me into them), I ran my fastest time ever in the car last night (I'm on the right side):
My prior best from a Wednesday night race was the 10.42 that I ran last week, so I picked up over a tenth from just the headers upgrade and thankfully didn't lose anything on the bottom end at the same time (which I was a little fearful of).
Given that I spun on my last pass and had already ran a few 1.35x 60ft times earlier in the evening, that 10.315 could have actually been a high 10.28. I'll be racing again this Monday and in the awesome early morning DA we get at Sonoma Raceway (when I ran there back on August 20th it was only 250ft on my first pass) I'm reasonably confident that I'll run a high 10.1xx but no worse than a low 10.2xx.
Anthony @ LGMotorsports (09-01-2016)
Supporting Vendor
This is a pretty complete front to back list of mods and/or stock equipment:
- RaceStar front skinnies with M&H radial tires
- Vette-Air intake system
- Attack Blue Air filter
- Stock LS7 air intake housing
- Dewitts radiator
- B&M transmission cooler
- Ported, stock LS7 intake manifold
- Stock LS7 injectors
- Stock alternator and water pump
- No front sway bar
- Stock spark plugs and wires
- Stock LS7 heads that have been milled .030 with stainless steel exhaust valves and stock titanium intake valves
- HUGE aftermarket cam from Vette-Air
- PAC 1207x valve springs
- Stock LS7 block
- Stock rods, crank and pistons
- Stock piston rings, rod, main and cam bearings
- Joe Gibbs LS30 engine oil
- Moroso Oil filter
- Fluidampr SFI approved LS3 harmonic balancer
- Scoggins Dickey harmonic balancer spacer
- ARP crank bolt
- Stock timing chain and gears
- Stock head gaskets
- Stock LS2 oil pan
- LG 1-7/8" headers with offroad x-pipe
- Borla Stinger mufflers
- MSD 8733 2-step launch controller
- Cartek line lock kit
- Upgraded 6L80E tranmission with Alto clutch packs
- Yank stall converter (approximately 4000 stall)
- ZR1 reproduction rims with 335/35/17 Hoosier drag radials
- Stock LS2 fuel pump
- Custom differential brace
- Z06 rear sway bar
- Stock C6 Z06 differential with reinforced upper ears
- Driveshaft Shop Level 2 axles
- 5 point custom built roll cage with driver side swing out bar
- Simpson Racing cam-lock 5 point safety harness
- Removed passenger seat
- Tuned by me with HP Tuners
- QA1 double adjustable shocks on all four corners
- 91 octane mixed with Aces-IV octane booster
Very impressive and love that shot with the wheels up.
Supporting Vendor
Supporting Vendor
Received 2,060 Likes
So how much difference did the proto Yank make?
Hitting Sac again (new plugs this time ) w/Bob and maybe Victor on Dec 31/Jan 1. Hope to see this in person.
Supporting Vendor
Received 1,674 Likes
Great shot!
Received 2,093 Likes
- Dewitts radiator
- No front sway bar
- Stock LS7 block
- Moroso Oil filter
- ARP crank bolt
- Stock LS2 oil pan
- Z06 rear sway bar
Car looks AWESOME!!!
