Received Some Terrible News Last Night
Hey people,
I have a c6 SV widebody with a ECS 1500 kit on it. I had some motor trouble about 3000 miles after installing the kit. I took the car to a shop about 5.5 hours away because I didn't trust any shops local to me. I will give a basic rundown of my experience so far:
* shipped car to the shop for SC install
* Drove car back home with noticeable sputtering issues at part throttle
* Car wouldn't cold start at all. (turned out it needed flood clear method due to meth pumping full time when keyed on)
* Drove car back to shop to check over issues (turned out it was a bad meth pump)
* Drove car back home for 2 weeks
* Took car back for fuel upgrade and more HP; needle bearings from rockers "grenaded" on dyno and went through block; shop flushed block, installed trunion upgrade and upgraded dual springs from weak prc duals previously installed
* Picked car up. Heard ticking noise but figured it was valvetrain that was just upgraded. Tuner was asked about issue but didn't think it was noteworthy.
* Drove car home and noticed lower than normal oil pressure before getting 100 miles away from shop; alerted tuner and kept driving since the car drove normal; car never dropped below 10psi during trip but still went up with rpm.
* Tried to drive the car the next day and it dropped below 10 psi and stopped responding with rpm. Ticking noise also seemed to get louder.
* Contacted Tuner, told him of noise and we agreed it wasn't ok..... I stated if it was bearings I wanted to hold off and do the rebuild on my own. Tuner was confident it was the oil pump. I sent car down on trailer (It drove up on trailer fine) and tuner ordered oil pump. (May 19, 2016)
* Tuner contacted me stating the metal in filter points to bearings and a rebuild would need to be done; Tuner sends oil sample to lab to determine what bearing material it was (needle bearing from rockers or main bearings).
* Tuner gets lab results back and we decide to proceed with rebuild and more small upgrades (cam, pulley, hd oil pump) Aug 4, 2016
* I got a pic saying car was getting ready for service the following Monday on a Friday evening. Aug 17, 2016
* Last night I get a text stating I need to come pick my car up as a roller with the whole S/C kit and wiring harness and accessories off the car because they are shutting down the shop.
Am I the only one who believes a shop should at least finish the cars they have in the shop before closing especially if they still had the manpower to do so? Should I just cut my losses and grab the car? Being 550 miles away doesn't help the matter, the car not being operable doesn't help the matter, and the money it will cost me to transport the immobilizes car with all of the parts 5.5 hours is also not helping the matter when I was expecting a fully functioning car able to be driven home by this time. Nearly 4 months later this is what I am getting....
Last edited by LSMAC; 09-08-2016 at 01:25 PM. Reason: I wrote 550 miles instead of 5.5 hours. My mistake!
Received 1,013 Likes
2016 Corvette of Year
2015 C6 of Year Finalist
what I got out of this was
"I took the car to a shop about 550 miles away because I didn't trust any shops local to me"
Fail
I agree, they should have at least finished the cars they were working on.
Fail
Sorry for your troubles. That is terrible news. Not a whole lot you can do about it now though.
I guess we know why they are going out of business.
Wow...and for those who wondered, this is why I want to do my own FI tune.
I guess I'd say no. Cut your losses and get the remnants of your car out of there. If they're going out of business there are myriad business issues you will never know about, and no one will be in the right frame of mind to get your car right, and if something else comes up you don't have anywhere to go. 550 miles away is crazy on that merit alone.
"Should" finish? Sure. Love that word.
But a good shop "should" be able to stay in business too.
But Blindspot's right -- a shop shutting down isn't focusing on getting your build 'right'; they're all preoccupied with little things like "where's my next paycheck coming from?" and "how am I going to cover my family's expenses in the meantime?"
Sucks, but here you are. Adapt and overcome.
Go get your car out of there, that's what I'd do. Try to find a reputable shop near the one it's at now so you don't have to transport the car far. Hell, they might even go pick it up if they want the business bad enough.
I would be real curious to know what shop you took it to...or at least , what city? Maybe another reputable shop close you can take it to. sorry for your troubles, hope you get it back together.
Sorry for your troubles brother, but it looks to me like they weren't on the ball to begin with and would only give you more of the same if you kept working with them. At least they gave you a heads up that they were shutting down, most business don't do that when they go **** up, they do a midnight run and leave everyone hanging. I would get he car out of there asap.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Having heard of what can and does happen when a shop closes down, or even a regular biz, I'd get that car out of there today, tonight, or tomorrow. Before it's gone. Because then, you have no one to go after. They'll be gone, too. Sorry for your troubles, but get the car and fast. jmo
St. Jude Donor '15
"In honor of jpee"
ECS just did above.
Did you have prior good experiences with the shop?
Whatever it looks to be a very very expensive ordeal, and your not thru yet
Good luck
NSF
PS another vote for leaving stock, unless you know the engine builder really well
Good luck
NSF
I would get the car out asap> the shop maybe under lock and key from a lender in short notice.
I encourage you to take the time to go down and make sure you get all of your parts - if you count on someone else to handle all of the parts they will grow legs and walk away.
Sorry this happened.
Race Car Tech
That is a terrible thing to happen, all the issues, then that text! As others have said, cut your losses, gert your stuff and get your car out of there ASAP!
csf (09-09-2016)
