2012 z06 steering wheel into my 07 z06
I did a search but found some conflicting info...
My 07 z06's steering wheel has radio controls on the right side but no Bluetooth buttons on the left
Will a 2012 z06 steering wheel with just radio controls be a direct swap? Or will I need a new harness / clock spring?
Thanks in advance
Thanks in advance
I swapped a 2012 wheel with radio controls into my base '07 with radio controls and no blue tooth, it was a direct swap, no new clock spring or wiring harness required.
Maybe there's variations among the models but I doubt it. I also found conflicting info on the internet and was prepared to order a new clock spring if it turned out to be necessary, but it wasn't. Give it a try, it should all plug right in, but if not, it's pretty easy to put it all back together and order the extra parts.
furiousox (09-14-2016)
You should be able to swap it in with no issues. I think the only model that would require a new clock spring would be the '05 models. I swapped a 2012 wheel into my '08 without any issues. Very easy.
