Starting issue just need some verification
Hey ya'll.
Went to start my 07 Z06 and it went click click and nothing. After a few more times trying to start it the clicking wouldn't even start and it said service needed soon/anti-lock brakes, I tried disconnecting the battery and the same thing with an occasional key FOB not found error. I put the key FOB in manually and still no start. I don't drive the car much but I just bought it 2 months ago with the same battery it came with. I did some searching and it seems like it might be the battery, and that I should have a tender. The only thing throwing me off is the service vehicle error and the fact that the cluster sweeps and one of my headlights works and my parking lots turn on. I am thinking there is enough juice to turn on lights but maybe not crank the car? Also the doors locked me in too so it really is sounding like a battery issue. A few weeks I went to start the car and it was a little tough to start and I figured it was a battery being dead.
I just wanted to make sure I was on the right track with things. Any tips would be useful. I've done a bit of searching but most of the threads ended with debating and the OP never came back to update the thread. I had a similar issue with my C5 and it was a battery.
Thanks for the help everyone.
KIMCHI (10-10-2016)
Thanks Speed07! I figured that much. When my C5 died it was weird as heck all sorts of weird things. My boost gauge worked but my radio didn't, half the dash worked, one light worked, and the car wouldn't click. This reminded me much of that. Just wanted to make sure I wasn't wasting my time and money on a battery. Off to Autozone!
I think I need a tender too. I work from home and don't drive much so sitting can't help the car.
I work from home too and always have mine on a tender since I don't drive it much.
KIMCHI (10-10-2016)
Race Car Tech
The battery and it's connections (battery posts, solenoid connectors) and grounds are a great place to start with. A C6 is very finicky when it comes to low voltage on a battery. It will give all kinds of weird alarms, lights etc.
Hopefully it is just a weak battery, possibly because of a shorted cell.
The batteries, if they go below 80% capacity, tend to short cells when recharged. All the corrosion on the plates when recharging, get shocked off, falls to the bottom and shorts out the cells. As the battery ages, this becomes more of a problem. Corrosion in a lead acid battery is unavoidable, but a battery that stays charged to close to 100% capacity at all times last much longer.
This is why a battery tender is a must for a C6.
Good Luck...and report back on any findings or solutions.
KIMCHI (10-10-2016)
Race Car Tech
You can't go wrong with either brand IMO
KIMCHI (10-10-2016)
The battery is really old. I took it to get tested and its beyond saving. Any tips on getting this out of the box? I have tried a bunch of methods and it just won't come out.
Thanks again for all the help guys and gals.
I am going to install it tomorrow. I am doing some reading on how to remove it and I'm exhausted from the day. I tried to jump it with my 2015 STI and the car had like 11v going through it and it was a "thats your problem!" moment.
Race Car Tech
http://www.z06vette.com/forums/f62/c...nstall-115727/
Good luck
If not you're in for some bloody knuckles & a lot of frustration.
Ask me how I know.
Must tuck one cable into hole, lift cell straight out. Real PITA on a Z.
Some members tried a vice grip on each pole, others used duct tape, a $2.50 lifting strap was my choice.
BTW even the cheapest Fleet-Farm tender's better than none, one's extra important in hot climates + infrequent operation. Tho' cold's just as hard on C6 batteries, if parked for prolonged periods.
FWIW my C's on a tender whenever not driven, w/ no exceptions.
Selling dealer sold me a leftover '08 3/09. Car had sat over a year, needed a power pak to start for test drive.
Next day deader than a doornail, said dealer sent a SALES guy to my home w/ a new Delco. Kid installed it & I watched, wasn't pretty.
Due solely to using a tender I've not experienced a single issue w/ batteries since the first incident.
The trick was taking the interior piece that runs along the back of the trunk. That allowed me to pull the plastic surround from the battery, move the cables and vent out of the way, and then I was able to slip some shoelaces under the battery and fashion a net to lift the battery out. Success! Battery came right out but I noticed the old battery didn't even have the vent hooked up!!! The previous owner must not have realized it came off. I plugged the vent back in put the battery back in the track, plugged it up, and bam car started like a champ!
Thanks for all the help everyone.
Landru (10-11-2016)
