what should i put under my tires for storage?
Old 11-22-2016, 12:22 PM
vettez4
vettez4's Avatar
Default what should i put under my tires for storage?
dont have a jack for all 4 sides
Old 11-22-2016, 12:33 PM
EVRose
EVRose's Avatar
This has been discussed here twice in the last week. I think the general consensus is you don't need to baby your tires during the winter. It won't be sitting that long and todays tires are not prone to flat spots. Just add a few extra pounds of air and say goodnight.
Gotta-Qik-C7 (12-07-2016)
Old 11-22-2016, 12:40 PM
vettez4
vettez4's Avatar
but would Styrofoam or rubber under them help?
Old 11-22-2016, 12:49 PM
jbc1995fb
jbc1995fb's Avatar
Received 1,335 Likes on 881 Posts
You could buy a couple sets of Vehicle Dollies. Jack up car and put these under each tire. Says works with Maximum loaded tire width not to exceed 13-9/16 in. (345mm).
http://www.harborfreight.com/1000-lb...-pc-61283.html
EVRose
EVRose's Avatar
Help what?
Bruze (11-22-2016)
Old 11-22-2016, 12:50 PM
vettez4
vettez4's Avatar
Help what?
flat spots
Old 11-22-2016, 01:38 PM
449er
449er's Avatar
Received 4,685 Likes on 2,984 Posts
flat spots
I know that you can buy pads for under the tires, but my car sits for 4 months on a concrete floor without moving with the factory run flats & I have had no issues
Old 11-22-2016, 01:40 PM
EVRose
EVRose's Avatar
flat spots
Did you read my first post?
Bruze (11-22-2016)
Old 11-22-2016, 06:20 PM
eshuber
eshuber's Avatar
Don't kid your self - Vette tires will flat spot if not used for more than a few days.
I have used a spare piece of carpet(house) with good results - cheap and easy.
Old 11-22-2016, 06:24 PM
449er
449er's Avatar
I am not kidding myself?? I have actually done this through a 4 month winter with NO issues, just my experience from actually doing it, I see you are from the big state of Texas, you probably have no experience with this
Old 11-22-2016, 06:28 PM
Tombovette
Tombovette's Avatar
Old 11-22-2016, 06:42 PM
Bruze
Bruze's Avatar
Received 1,136 Likes on 882 Posts
LOL @ this urban myth.
I stored cars in the winter in the late '60s and never had any issues with "flat spots" -- even with the "low tech" tire compounds back then. And I've stored motorcycles since 1970, for 5-6 months at a stretch, no issues.
So has it ever happened? Probably sometime, somewhere. But for a few months, with modern tires? Let's see some documented evidence.
A bigger worry -- depending on where you live -- is mice destroying wiring harnesses.
Old 11-22-2016, 06:46 PM
z06clif
z06clif's Avatar
Is it necessary to store your car in Vegas in the winter? Or are you going away? Anyway I never put anything under the tires and my car is stored for 4 months every year.
Old 11-22-2016, 06:54 PM
HBsurfer
HBsurfer's Avatar
Received 1,105 Likes on 706 Posts
Flat spots after a few days?
The following 3 users liked this post by HBsurfer:
usr5000 (12-10-2016), Vegas1500 (12-08-2016), vettelover69 (11-26-2016)
Old 11-22-2016, 07:11 PM
tealex
tealex's Avatar
I pump up the air pressure to about 38-40lbs and park it on 4 pieces of 1/2 inch plywood to keep the tires off the concrete. I read somewhere that it's the damp, cold concrete that is not good for the tires.
Old 11-22-2016, 07:32 PM
Bruze
Bruze's Avatar
Only with "Vette tires!"
Old 11-22-2016, 08:16 PM
airmed2
airmed2's Avatar
This kind of stuff cracks me up. Are any of you part of the Cupcake gnereation?
To what should i put under my tires for storage?
Old 11-22-2016, 08:30 PM
5knives
5knives's Avatar
your garage floor
Old 11-22-2016, 10:45 PM
buckmeister2
buckmeister2's Avatar
Received 1,206 Likes on 824 Posts
The only thing that could help, though "help" is not needed, is something that is formed to fit the tire. This would (unnecessarily) distribute the load more.
Unless your tires are over 5 years old, and you are concerned about cracking, there is little benefit to doing anything other that adding about 5 pounds more air. JMO, though.
Old 11-22-2016, 10:59 PM
buckmeister2
Tires are already made of rubber, so additional rubber will not cushion them better. The only thing that will help, though "help" is not needed, is something that is formed to fit the tire. This would (unnecessarily) distribute the load more.
Quick Reply: what should i put under my tires for storage?
