How to Air-up Michelin PSS ZP 335/25/20 Tires
I have four new Michelin Pilot Sport A/S 3+ sitting in the corner of my living room waiting to be mounted on my base model. Does this mean I'm gonna have problems to?
Received 1,334 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
I read somewhere here on CF that this works. No experience with it myself.
http://www.tulstar.com/products/oils...eat-tire-lube/
I was at my favorite tire shop that I've used on many sets of tires/rims on my GS. There was a C7 Z06 in that day too. They dealt with these rim/tire combo many, many time before, but this day they had a hella bad time. These guys normally sling these on many times a week. They finally used (yes they have all of the specialized stuff; cheetah bar, big air tank, etc.) a rubber hose to temporarily seal the area while blasting in air at the same time...
Point is, even the pro's that do these quite often have a bitch of a time...
My opinion, worth what you paid for it...
Their customer service is excellent though & they were in constant contact to see how it was working, but still didn't get the job done in the end, at least for me.
Find a shop that can actually repair aluminum wheels. They usually have the best equipment.
Thee appears to be two issues people are responding to.
1. Getting RFT ZR1/Cup rear tires on/off the wheel.
2. Getting the tire's bead to set once the tire is successfully on the wheel.
I've had two different sets of rears mounted on my ZR1 rear wheels. In both cases the shop (Discount tire with high dollar touchless tire mounting machine) was able to get the tires on the wheels (Issue #1) using rim savers and lube to aid the tire in sliding up and over the wheel lip.
As for seating the beads, they only had to attempt more than once on one tire to get the bead to set.
1 issue I think. It's no problem getting the tires on the rims. Getting the bead to seat is the issue.
Final Report on Michelin PSS ZP 335x25x20 tires on GM "Cup" wheels.
My original tire person got them all aired up and picked them up today. No damage to the wheels. Also took very small amount of weight to balance, much less then the Good Years.
Their were no magic techniques or liquids that worked for this tire/wheel combination install.
Basics of what worked:
1). Installing tires on wheel, very easy, no problem;
2). Airing up tire, getting bead to seal, is the difficult part. The four wheels took about 6 hrs to air-up. Could easily get the bead to about four inches from sealing, getting the last few inches of bead to seal is the hard part. How it was done, shop air (not regulated) into tire valve, keeping the bead area of tire well lubricated with water/soap solution, and wheel surface in the area. You lift and streach, then release the bead area until it slips on, just keep doing it and eventually it goes on. Just keep it lubricated so that when it starts to go on, it goes all the way.
Their is more technical detail as to why this happens with this combination, regarding the bead area construction along with Cup wheel shape.
Special thanks also goes out to the Corvette museum in Bowling Green technical staff that helped.
#34
Short driving around town, tires seem very nice and quite, max speed 60mph. Fronts really stick, need to make turns with car moving, not real sharp, otherwise they scuff in sharper turns.
One last photo of the new tires.
#35
The air is blasted between the bead and the wheel. You remove the valve core and hook up shop air with it constantly flowing while doing this. We don't work in tire stores. That is why its concerning. You can also damage the hell out of wheel with one if you arent careful.
https://www.amazon.com/TSI-Cheetah-B.../dp/B000VNHWUM
Works like this.
Turn your speakers off. Video is loud.
Works like this.
#36
Edward,
Agree the redneck method does not work. Their is one method that works. All the special ways or products, or tire machines do not help for this tire/wheel combination.
Les
Les
