Clunking in the rear
Check this thread out:
https://www.corvetteforum.com/forums...ing-noise.html
It is likely one of three things:
Loose axle nuts
Need a rear end fluid change (What it ended up being for me)
Sway bar end links
Loose axle nuts
Sway bar end links
Received 3,626 Likes
2016 C6 of Year Finalist
They are behind the wheels.
Some guys just remove the wheel center cap and tighten them with the car on the ground.
1-5/16 or 33mm socket will work just fine on them.
Some have reported that they come loose even at that spec so adding a bit of thread locker or a Nord washer is up to you.
Document ID# 2018487
2005 Chevrolet Corvette
Subject: Tapping or Scraping Noise From Rear Wheel Area (Replace Wheel Drive Shaft Nut) #07-04-95-001 - (09/26/2007)
Models: 2005-2008 Cadillac XLR
2005-2008 Chevrolet Corvette
Condition
Some customers may comment on a tapping or a scraping noise coming from the rear wheel area.
Cause
This condition may be due to the torque on the wheel drive shaft nut relaxing over time.
Correction
Replace the left and the right wheel drive shaft nut following the procedure below.
Remove the center cap from the rim.
Remove and discard the wheel drive shaft nut.
Apply LOCTITE™ 272, or equivalent, to the threads of the axle shaft.
Install the nut and tighten to the new specification.
Tighten
Tighten the nut to 215 N·m (160 lb ft).
Install the center cap to the rim.
Important: The vehicle should not be driven for 24 hours following the repair in order to allow the thread lock to cure.
Parts Information
Part Number
Description
Qty
10257766
Nut
2 (one per side)
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
F9712*
Wheel Drive Shaft Nut - Replace
0.3 hr
*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Condition
Cause
Correction
Tighten
Parts Information
Part Number
Description
Qty
10257766
Nut
2 (one per side)
Labor Operation
Description
Labor Time
F9712*
0.3 hr
I have an '06 I bought used that had the same issue. What I found that one of the sway bar bolts had come out.....while it sounds like a simple fix, the issue was that the "U" bracket holding the sway bar had bent and distorted a bit, making it difficult to align the new bolt to draw it in. Ultimately had to use a C clamp and some muscle to get the bolt started!!!!
NSF
Cherokee Nation (12-18-2016)
Got the socket. My torque wrench doesn't go that high. I have a 24" breaker bar and was barely able to move the nuts so I don't think that was the clunking sound.
My end links and axle nuts were fine. For me, it was the diff fluid.
I have only heard the clunk one time when going over speed bumps with a pasanger in the seat. Doesn't do it when I am alone. What I will hear occasionally is what sounds like a body pop.
The top did that when I first got it and the dealer fixed it. When I hear it now, it is not coming from the top.
Doesn't sound to me like diff fluid. When it's up on the rack be sure to bang around on all the exhaust, look for contact spots, etc. However, if it's on a lift it will not be settled as it is on the ground.
