C6 Jack points
Old Jan 1, 2017 | 03:43 PM
rolaszek1986's Avatar
rolaszek1986
Cruising
Default C6 Jack points
I have a 2 post lift in my garage. Want to lift my C6.
Jacking points listed in manual seem to be in a difficult spot.
Mid America sells jacking pads that fit in shipping slots under rockers.
Any body with experience with these. Or recommendation for positioning on lift.
Thank You
Old Jan 1, 2017 | 03:52 PM
jdvann's Avatar
jdvann
Those points(tie down) with the pucks are the right spot for using with a lift.
Jim
Old Jan 1, 2017 | 09:29 PM
HK770's Avatar
HK770
Old Jan 1, 2017 | 09:42 PM
jjbravo1's Avatar
jjbravo1
I've bought these for both my old C5 and the C6. No pucks needed now...
http://www.aacorvette.com/performanc...products_id=91
Old Jan 2, 2017 | 07:53 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Originally Posted by HK770
Old Jan 2, 2017 | 08:08 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
You may not be able to use the normal lift pad in the rear with a 2 post. Until I got shorter arms for the rear of my lift, I had to put hockey pucks on the arm itself.
Old Jan 2, 2017 | 09:22 AM
449er's Avatar
449er
CF Community Team
I would lift the car using the factory tie down lifting locations, buy a set a lifting pucks & you will be fine
To C6 Jack points
