Gas Gas Gas Gas
Gas Gas Gas Gas
Thinking about this at work, looking forward to spring and good weather. What type of gas and octane do you put in your pride and joy....87, 89, 90ish...any special brand?? How low do you let your tank go down before you will up?? Just curious....
Received 3,066 Likes
2021 C6 of the Year Finalist - Modified
Since I live in Florida, all I ever put in my GS is 93 octane gas.
However, I am not picky as to what brand I use. And I could care less if it's 'top-tier' or not.
91 octane always. Chevron, Shell or Mobil.
My owner's manual says 93 octane, so that's what I use. Why would you use anything else?
Received 2,093 Likes
Received 1,673 Likes
91 is about all you can find here.
is it bad if i put in 87?
Other than the knock sensors in the engine will detect detonation and will retard your timing way back so you don't damage the engine.
Keep putting in 87 octane gas ... You won't physically destroy the engine, but you are cheating yourself out of lots of HP dues to low ignition timing.
Here is some advice for you .... Put that low 87 octane gas in your lawn mower, and keep it out of your Corvette !
