C6 ZHZ wheel fitment. HELP!
Hi All,
I'm graduating from my C5 Z06 to a 2008 C6 ZHZ coupe. I know limited production units are hard to get accurate information on but I have a question about wheels on the ZHZ that you can hopefully help with.
As stated before, the car in question is a 2008 ZHZ coupe. The wheels on the car right now are quite large aftermarket wheels, I'd have to say 21 inch? If that's even a possible fitment. And frankly, kinda tacky looking.
I obviously want to put C6 wheels on (base model, Z06, GS, not sure yet). I know the ZHZ has larger brakes so the 18 inch fronts and 19 inch rears on the base are more than likely not going to work. I wonder what the proper size/fitment is on the ZHZ's.
Unfortunately, I'm not finding much on the internet. My best guess would be Z06 spec wheels? Does anyone know what that fitment is? Diameter is the main issue here.
Any and all input would be highly appreciated!
ZHZ had base fitment for wheels. They had standard brakes on all ZHZ models. They also all had F55 suspension and NPP exhaust. If your ZHZ has big brakes then it did not come with them. Wheels were Front: 18x8.5 245 40ZR18 Rear: 19x10 285 /35ZR19.
Brakes seen here are standard on ZHZ. Only they weren't painted yellow.
you didn't buy a "limited production unit" you bought a rental car what do you think ZHZ stands for? try HERTZ obviously someone bought it after it's term as a rental and put those wheels on it, base/Z51 wheels won't fit without spacers, just look for a set of stock ZO6 wheels or aftermarket made for that fitment.
Received 1,013 Likes
2016 Corvette of Year
2015 C6 of Year Finalist
Csalads09 (01-30-2017)
I'm going by the ZHZ Registry: http://www.corvettezhzregistry.com/?p=52
But hey, not everything you read on the internet is true! Specifically referring to "Special limited edition built by General Motors"
As per the brakes, I was going off of "Larger cross-drilled rotors"
I'm gonna get the car to a shop at some point so I can inspect it myself on a lift at some point this week. Here's a picture of the wheel where you can see the brake via the seller. I've distorted the color a bit so the brake setup can be seen a little better.
I'd be happy if I can get some GS/Z06 wheels on that sucker. These just aren't my style. If all goes well and I end up pulling the trigger on the car these wheels will end up on here and Craigslist for very cheap
Thanks for the input guys, I was unaware that this was a rental car TBH. I thought the tie in with Hertz meant it was similar to the 2005-2008 Mustang thing they did. Whoops!
I thought they looked a tad larger than stock C6 rotors. I've seen a few reps floating around eBay. So if the 18/19 base setup won't fit I believe I should be on the lookout for a 19/20 setup?
Thanks!
Yeah, those are regular Z51 brakes so you need regular base corvette wheels. The Z06 or GS wheels will stick out too far. I bet you can find someone to trade you via craigslist etc. I see the car has a Carbon fiber lip as well. Post some more pics of the car, maybe we can tell what other upgraded goodies it has.
You can also look for stock C7's take off's in the 19 and 20's. I think they bolt right up.
The stock ZHZ wheels (in the second post) were actually excellent wheels if you like chrome. Unlike most base C6 wheels they were forged, so they are light and strong. But as others have said, any base (not Z06/GS/ZR1) wheel will fit over the J55 brakes.
Received 2,060 Likes
Geez! I can't believe the amount of poor/bad/mis-informed info on this thread.
The 2008 ZHZ was a 500 unit special limited run base car produced for Hertz at the end of standard '08 MY production. In addition to nearly every option available, it had special Hertz identification items. Almost, but not every one, was used as a regular Hertz rental and then eventually sold to the general public.
One of the options was the F55 mag-ride that included J55 brakes, also often referred to (in ignorance) as Z51 brakes. They have larger rotors than the standard J9L brakes and are drilled. All C6 base wheels, regardless of year, style. or brakes are the same size. The ZHZ used a 7-spoke wheel (shown in post #2 along with the J55 brakes) that later became a dealer available option and due to the limited quantity manufactured are unique and somewhat rare. The Z06 and GS wheels are wider and require wider tires, which will stick out beyond the body of a base car.
Check the list of options on the glovebox lid and also go to http://www.corvetteactioncenter.com/specs/c6/2008/ for more info about options and other items of interest about your '08.
BTW, one of the forum members bought one with about 50K on the odometer and sold it with more than 270K showing. She said she only spent slightly over $1K on repairs beyond normal maintenance. Just because it was a rental doesn't mean it's a POS.
Pro Mechanic
Received 3,938 Likes
should be "end of discussion"................or so we hope.....
I found a set of lightly used base C6 wheels ('08 MY) that seem to be more realistic because the only ZHZ 7-spokes I found cost an arm and a leg, or they were for local pickup far from me. Problem solved! That's what I'll be going with if all is well with the car.
From what I understood from the ZHZ Corvette Registry, they come with a dual mode exhaust, no sense in hacking that up and swapping it with another unit I take. Or is there?
I'll definitely be slapping an intake of some kind in there if the deal goes through. Maybe a few cosmetic goodies as well.
Lastly I completely agree with the forum member who drove it til 270k before selling because that's EXACTLY what I plan to do. I bought my C5 Z06 with 17k miles on it and accumulated well over 200k before passing it along to my brother. Same with my base C5. I think I had 212k on it when I sold it. That's what I love about these cars. Try doing that with any of my other toys and I'll be in debt for the rest of my life.
Thanks for your help, really!
It does happen. How common that is? I have no clue.
There was actually a YouTube video of a guy putting a 150 shot on a ZHZ. He ran it for the weekend, then returned the car to Hertz. No thanks. Just go to YouTube and search ZHZ Corvette. Too many folks abusing them.
FAUEE (10-14-2023)
