Telescopic Column Install -Clock Spring/Steering Wheel Position Sensor Question
So I finally figured out the wiring and now am going to install telescopic steering column in my 1LT Base .
(if anyone needs the schematic on how to build the harness and relay's that are needed let me know as the factory harness in a 1LT does not have what you need )
My column that I bought did not come with a clock spring but has a steering wheel position sensor . My plan is to transfer over my existing parts to the new column including my steering wheel positon sensor but I am not sure how to do this as I am confident that the wheel has to be in a certain position before mounting these components
Does anyone have the directions on how to install these two items
Thanks in advance
Dave
Thanks in advance
Dave
Race Car Tech
I have info based on a 2005, so I'm not sure if this holds true for the later models, or if this info will be of any help.
Here is also a thread on the steering column from last week or so.
https://www.corvetteforum.com/forums...ng-sensor.html
http://fbdylvr.thruhere.net:9001/ser...did=865&evc=sm
Dcasole (02-05-2017)
Any info on the clock spring ?
Dave
Since my car is a 1LT, I don't have the memory function hence no ability to use soft stops so I can cross that off the list . I built a reversing circuit that uses the factory connector's , relays and switch on the column . works pretty good and looks just like the factory made it
The steering wheel sensor position and the ANGLE reset data is awesome ... I have a tech II so that will be no problem resetting
this is why I love these forums......
Dave
This may be the link Paul (lvtour) was steering you towards. Unfortunately, it only goes to 2005, and when trying to copy specific pages it just doesn't seem to work well. You'll need to drill down to the vehicle & systems you're trying to work on.
http://fbdylvr.thruhere.net:9001/servlets/Home
Race Car Tech
They do copy but without the pictures. I can use a capture program to copy the pics, and put them where they belong with the text.
Thank You for helping Dave out with the info he needed.
Every time I've tried to copy/past a hyperlink to a specific page from that site, it just seems to be a dead link a day or 2 later.
It's too bad because sometimes it will be a treasure hunt to someone unfamiliar with GM eSi. The good news is they'll tend to find a lot of other good info in their search
As far as copying entire article from that site, I just use 'print to .pdf' with win 10 and it puts it all there including pictures. Works just like the real eSI program in that regard. Only drawback is you can't really add more info like a Word doc.
Joe
Next is memory and heated seats , then with all I have already done to the car it will be a 3LT lol
I know ... people will say why did you just not buy a 3 LT .... because I love figuring this stuff out and working on my car
Dave
