Another Kooks Install
Not much more to report than the other recent threads on header installs.
Getting the OEM stuff off was not bad, getting the car on the lift was worse. For some reason the lift points and the lift arms did not want to cooperate, they are so close together and the lift arms were so long the car sat 2/3 behind center point of the 2 post lift after we finally got it in position. Made me very nervous but we shoved on it after lifting a foot or so, plus we used a 2 ton jack stand in the rear just for safety sake and it was stable.
Had a few hiccups which I wont go into detail about, this was the first experience we had with headers on a Corvette so there were questions on how, but all in all it came out very clean. I'm proud of the job we did and with great satisfaction
Kooks make s a nice product, fit was aces, and cant say enough about Stage 8 fasteners
Took it for a short test run and all went well, no leaks, no CEL's
Now for the good part, Sound was so different, I didn't expect it but its nice, at idle and slow take offs almost the same with NPP open of course, but mash the long pedal and WHOO-HOO, cant describe it accurately but LOUD it was.
Now performance wise, maybe my wallet was trying to convince me it was all worth it, I don't know but it felt and pulled much stronger than I expected, maybe just the excitement ?? But I don't think so.
Was it worth it, only time will tell
Will be going to the dyno In a week or 2 if all goes according to plan, That will be fun
Sorry but no photos, you've seen them before anyways and I was too focused on the work going on.
Hopefully I will remember to video the dyno tune, planning on it
One suggestion, if so inclined to install headers, DO IT ON A LIFT PERIOD!!!!!!!
NSF
NSF
NSF
Now if I see that much more improvement with the dyno tune I'll have a GIANT SMILE
Its been a long wait eh Bruce, so party is in order, as long as its over by 9:30 pm
Bobby
OMG, I just watched a vid on the fasteners. Those c-clips remind me of very small cotter pins and dropping them in the engine bay when doing anything with carb linkage. A friend gave me a package of all sizes of small cotter pins, called them "Jesus pins" because when you lose one, you say something not so nice. Unless you have some kind of great c-clip pliers which probably don't exist, I'd need 3 of them for every one that's supposed to go on the bolt.
My father walked outside with me yesterday and is approaching 70, looks at the car and says "Son, I don't see too many of these vehicles without gray or white hair behind the wheel.. you must be doing something right."
AORoads - Jesus pin haha.. Reminds me of:
Jesus nut or Jesus pin is the main rotor retaining nut that holds the main rotor to the mast of some helicopters, such as the UH-1 Iroquois helicopter; or more generally is any component that represents a single point of failure with catastrophic consequences.
Quite an accomplishment and something for which you can definitely be proud. The aches and pains will fade, but you'll be left with the memories of the conquer!...
...."You did it your way"....
Dave
and don't know if its true or not but somewhere in Kooks literature they stated their cats are 400 cells VS others at 200 cells, less likely to setoff CEL's
NSF
if you don't have a CEL yet .... you will get it eventually , but the rear O2 sensors will be turned off in a tune
Dave
Dave
" cause I sure don't Bobby
If you drive it long enough you will, but some do not get a cel because they get a tune before the ecm does the test or the ecm was ready to do the test right away......
In my case , i never got the cel , so my ecm must have just tested the cats when i installed my headers and was not scheduled to test again for a while
