Just another latest greatest
I read al the posts about the latest greatest auto products on car care, and some are very good but I don't remember anything on these little jewels.
I consider myself fairly informed when it comes to paint care, I believe my car stacks pretty well for a street car, anyways I have always been a big time fan of Clay for removing surface contaminants but I saw some videos of this product and thought what the hell, I'll try it.
I found it took a little getting used to but after following the directions it does an amazingly fast and easy job, so good I threw away my clay.
It is the NanoSkin Auto Scrub, and its reusable, just rinse it off, if you want to get rid of the little grit on your paint it works wonders and so easy, so easy!!!!!
Anyways that's it, simple to use and great results
NSF
NSF
Received 3,626 Likes
2016 C6 of Year Finalist
...Anyways that's it, simple to use and great results
NSF
https://www.amazon.com/Nanoskin-AS-0...nano+autoscrub
NSF
Pro Mechanic
Received 3,952 Likes
Why / what took getting used too? Any marring? Remove all contaminants easily?
when you finish yours will you do mine........
At first I tried using plain water as I did with clay and the "skin" would drag/ get stuck sort of, plus I was using too much pressure. So then I started using a detailing spray and just gliding the "skin" across the surface ever so lightly, I know it doesn't seem possible but it takes off the contaminants better than clay, I just did my car as it had a hint of grit on it, most would never feel it but I'm pretty ****, literally took me about 10 minutes, smooth as a babies butt. So 2morrow I will use my DA with a black polishing pad with Meguiars Ultimate Synthetic wax (which I love) and she will be ready for take off.
Maybe try this video, but there are many on this product plus there is a red sponge that is for more contaminated paint.
Happy Scrubbing
NSF PS I should clarify that I did only the top surfaces in 10 min.
rkj427 (03-31-2017)
Thanks, I'll give it a try.
