Transmission Shift Cable
The "great" dealership that drained oil without adding any is in Illinois. Same one that sells a lot of Corvettes yet still managed to break a rocker panel by not lifting mine correctly the first time I went there.
Received 1,136 Likes
If Bruze posts a pic of my cable, it had about 35,000 miles on it and was on my 2007.
It looked pretty good but maybe a little worse than the photos Vet just posted.
Mine was probably fine but considering the grommets are plastic, I would think that failure would be sudden. Metal will slowly fatigue and show wear over time but plastic just snaps. I think appearances in this case may be misleading.
There really is no difference between HB's cable and mine. I had to mark them so I didn't mix them up.
His: '07 35k miles; mine: '07 31k miles. (Thanks again, HB! )
A somewhat depressing surprise: I bought the new cable from the local Chevy dealer. My buddy handed me a sticker today that was on the cable. It said "Made in China."
I don't recall anyone on CF mentioning this, and I've read all the cable threads. Is this new? I wonder if the plastic ends are recycled from the plastic Japanese toys I played with as a kid in the '50s, that would break when I dropped them on the floor . . . ?
Vet Interested (06-24-2017)
I ordered new (Dorman) groments for both ends and replaced them both in about a couple hours. Total costs was about $9. The cable isn't what fails, it is the grommets. The only hard part was getting the old grommets to release from the cable.
https://www.corvetteforum.com/forums...e-grommet.html
HammerheadTed (06-24-2017)
I hope to do mine soon. Looks like it's a hard job, but if you change the grommets, it doesn't require removing the tunnel cover or the exhaust(maybe). If you replace the cable, you skip what seems to be one of the hardest things in getting the old grommets out and putting the new ones in, but tunnel cover and exhaust must be removed. CORRECT??
Received 1,496 Likes
I have read of people's cable breaking too, I would change the entire cable rather than do the grommets and yes tunnel plate/exhaust will have to be removed to do the grommets alone as well.
I replaced both grommets on my car by just removing the shifter. I did not have to remove the exhaust or tunnel plate. Getting the old grommet off the transmission end of the cable was a bit of a challenge, but I managed to do it without taking anything off the car.
The only time I've heard of a cable actually breaking was after someone stressed it too much while trying to replace the grommets in it. That is a risk, and you do have to be careful not to lift up on the cable too much on the front when you are trying to replace the grommet on the shifter end of the cable.
I think most of the aftermarket grommets are also made of polyurethane instead of nylon, so they may last longer than the OEM ones that come on a new shift cable. If I bought a new cable, I'd seriously consider replacing the grommets on both ends before installing it. Otherwise, you'll be back in the same boat in a few more years.
Mad*Max (06-24-2017)
Here is a link to the dorman site. It shows their bushings are made of polyurethane. OEM are nylon and this is the root of the problem.
http://www.dormanproducts.com/itemde...9&SEName=14055
Got my car back from my buddy today. He put in a new cable, snapped the locking pawl off, and did some other things I needed done. At least I'm not going to be paranoid of using the shift lever now. It should last the rest of my years . . . the sane ones that are left anyway, ha.
Received 2,093 Likes
Looking at these two cables, HB's cable looks like it might be a little cleaner. But zooming in on Bruce's cable, are those casting marks, wear marks or cracks. Then again it could be nothing. Interesting to check out.
Thanks for posting.
Actually, zooming in on HB's cable I can faintly see the same marks so it must be casting. Oh well....
Thanks for posting.
The odds of GM using the wrong material is highly unlikely, and I have no love for GM except that they make a great sports car. In the complex world of polymers, this is pretty simple stuff.
#33
Glad you got it done before getting stranded. I was paranoid every time I used the car until I replaced my cable. I did not notice where my cable was made. Never relay looked. I think I used the box to send you the old cable. Never noticed made in China, but it sure is possible
Bruze (06-24-2017)
#34
Thanks for posting.
Thanks for posting.
It has been noted, in other threads as I recall, that maybe heat has some effect on the bushings. The climate where HB is and where I am is dramatically different. In ten years and around the same mileage, the difference in temperatures has had no obvious effect.
The one, and only one, advantage of being on the wrong end of life is that you can see an end to things: It's highly unlikely that I will need another tranny cable on my C6, I will only need one more roof on my barn and probably my house, maybe two new trucks, one more chimney (which I'm getting replaced this year), etc., etc.
But aside from that, I'd still like to be 18 again.
#35
Choosing the right polymer per application isn't rocket science, but there is a lot of (other) science behind it. Do engineers get into heated debates about which is the right one? Haha, I'm sure they do, although I've never seen it.
If the failure rate of C6 tranny cable bushings is notably higher than other makes and models, then they probably should have used bronze instead of plastic, although that wouldn't solve the riddle of WHY do they fail more often than other cars? -- all else being equal.
#36
Everything deteriorates in time, even granite. Some plastics would probably deteriorate even quicker under the same conditions.
#37
So, i think age is a reason too.
#38
#40
Man....all this talk about the inevitable shifting cable blues is depressing... thanks GM.... I know what my dumb a$$ will do about it. Nothing. Then one day i'll be cursing up a storm somewhere cause i didn't do the right thing and change it before it broke.....
