Door wont open
Old Apr 7, 2017 | 04:44 PM
2008C6Owner's Avatar
2008C6Owner
3rd Gear
Default Door wont open
So my driver door still won't open from the inside or outside i have to use the emergency handles ,i got a new latch ,new fob battery ,new door pad , disconnected the battery and still nothing, the door indexes but still no go. Help please . Also my passenger side works perfect . Also here a clicking sound when trying to open my door by my glove compartment. .....
Old Apr 7, 2017 | 07:41 PM
2008C6Owner
3rd Gear
Default Door wont open can't figure out !!
Old Apr 7, 2017 | 08:15 PM
MLRS's Avatar
MLRS
Have you removed the door panel to do anything like change door speaker, etc? It happened to me once after changing the speaker few weeks later the door was doing the same thing and when I pulled the panel out the big wire connector had come loose, reconnect it and problem solved.
Old Apr 10, 2017 | 07:54 PM
2008C6Owner
3rd Gear
I did change my speaker and ill give it another check but i'M pretty sure i reconnected , if thats not the problem do you have any other solution ?
Old Apr 10, 2017 | 10:53 PM
MLRS's Avatar
MLRS
No, I did connect the big wire connector piug that somehow came loose, That was my fix.
To Door wont open
