C6 rear rattle
Cruising
C6 rear rattle
I have a 2011 with 43K miles. I have a rattle underneath when the RPMs are around 6K. Performance is great, no problems when accelerating. Had what seems like the same problem about 2 years ago. Dealer had it for 1.5 weeks, so not much confidence as what they did to solve the problem. I'm experiencing the same noise, and the car is older than 5 years. Anyone have history on this?
Much appreciated,
Ray
Much appreciated,
Ray
Cruising
Jack the car up.
Take a rubber hammer to the exhaust first, then everything else.
Rattles can be tricky, don't rule out that the rattle is coming from the front or the interior.
Good hunting.
Good hunting.
Rhelbig (05-05-2017)
Sometimes the intermediate pipe rear hanger springs will rattle because the exhaust isn't putting tension on the spring(s). Check there. If that's where you're noise is coming from, pull the hangers out and spray them with plasti-dip. The rubberized coating will dampen the metal to metal rattling that you're experiencing
Agree. Same problem with mine at idle, sounded like a can of marbles. Sound would go away under load. Car ran fine. Noise will get louder with time. Front bearings in Toque Tube bad. Good Luck.
Cruising
That's, the torque tube. Dealer quoting $2400. Car is 5.5 years old, 43K miles. Last year it was the alternator at 37 K miles, $1100. I called GM looking for some help, they told me to **** off. Let's just say my love affair with GM is strained.
Torque Tube bearings growling
In reading other posts on the subject, it appears that quite a few other folks have experienced the same problem. I'm wondering if and how they truly fixed the problem. And if the growling noise returned after 4 or 5 thousand miles or not. (Or were they frustrated enough and sold the car out of spite? I am rapidly approaching that point, as much as I hate to!) HELP!!!
And by the way, how many miles have you put on the repair job since it was completed? Any hint of returning noise or growling?
Cruising
Torque tube is done. Took the Ft. Myers dealer 2 weeks, and a door scuff on my door, which they have take care of. Since GM told me to **** off, I'm looking for a good mechanic in the Ft. Myers/Cape Coral area, if anyone knows one.
Thanks all for your input,
Ray
Ray
Received 1,675 Likes
Maybe the cat back is loose?
Cruising
Turns out it was the second time the torque tube was replaced. First time was under warranty at about 20,000 miles. Hope this replacement lasts longer.
