Glovebox cover and frame separation
The glove box door frame contains the build info for the car. If the glove box is damaged and has to be replaced, has anyone found a way to separate the door frame from the front of the glove box? Peeling the
data sheet off the frame is haphazard at best, likely to be damaged.
Race Car Tech
If done correctly, it will look just like the original.
Water resistant labels can be purchased by the sheet or in a package from any office supply company, or online from companies such as Creative Label Concepts, etc.
I would take the picture first, then i would get a hair dryer and a razor blade and try removing the sticker it can be done without destroying the sticker, but if you do you would still have the picture for a back up.
