z06 exhaust manifolds swap to base engine help!!
Folks,
I have my truck at a shop now to get the Z06 manifolds, downpipe, and x pipe installed in place of the base system. thge shop just called and said the manifold ports do not match up...the z06 is a round port, and the base is a "3/4" port (his words over the phone, and that the exhaust will plow out the gasket. Makes no sense to me, but I need help from those who have done it.
Jim
Jim
So, are earlier Z06 ports round? I was under the impression that they were the same from '06 to at least '09. The gaskets for the base LS3 do not appear to have enough material at the bottom to guarantee a seal with the Z06 manifold. That is why we used the Z06 gaskets. Am I missing something?
Jim
Use the Z06 gaskets and you are good to go. Don't worry about the different shapes, it appears that everything works.
Here is a good thread with pics; https://www.corvetteforum.com/forums...completed.html
Thanks for all the help.
Jim
[QUOTE=CMY SIX;1594730913]so what's the point of doing this mod if your going to use the stock mufflers?[/QUOTE
Your question makes sense. The stock mufflers have more than enough flow to handle the improvement of the Z06 manifolds and down-pipes. Many folks, on this forum and elsewhere, have done this without changing muffs as an economical way to gain HP. I am not looking for loud, just a bit more performance while retaining the stock appearance.
[QUOTE=buckmeister2;1594731028]
After reading your reply Jim, mine sounds like I'm a grumpy old man.
buckmeister2 (05-13-2017)
I done the mod on my 2006, but the complete system
