Fluttering noise c6
Agreeing with others, check the cowl cover for a loose fit, front air deflectors, front grill, splash guards and inner fender panels. Most likely the front cowl cover is loose. I would go ahead and check everything while you are at it.
Make sure when you do this you get the tape to hold the rubber sealing edge of the cowling down on the glass. Do not tape the rubber edge down, keep the VHB tape on the hard plastic.
My guess is the OP got fed up with the whole thing and sold it in 2017.
The following 3 users liked this post by 87SAM:
The following 3 users liked this post by Dutch08:
