Faulty door latch
Faulty door latch
Guys, need help
I'm not able to open my driver side door either from the inside by pressing the open button or from the outside , all that happens while I try is that the window tilts down a bit and then again rolls back up, I cAn only open the door by using the manual lever below the driver side seat or by pulling the latch inside the boot. What shud I check? Or wat needs to be changed? Do advise.
Guys, need help
Steve
FortMorganAl (05-15-2017)
My 2005 coupe did the same thing. It was the door module. Chevrolet replaced it, even though the car was out of warranty. You might want to check with someone from Chevy about it. Good luck.
Received 2,060 Likes
It looks like the OP did a correct diagnosis in his thread title and extrapilot posted the replacement process.
It's why this forum rocks.
I just replaced the latch solenoid on the wife's Caddy last week and it's a much bigger PITA than the Vette.
And the fact that the window moves proves it has absolutely nothing to do with the FOB. In the case of opening a door, the FOB is only used to decide if the door should be allowed to start opening or if the locked condition is to be maintained. Once the window moves that decision has already been made.
It is also very unlikely that it is the door module since the same module controls indexing the window. To be the module it would have to have a failed digital communications to the Body Control Module (BCM) computer yet still digitally communicate to the BCM when it is told to initiate opening by lowering the window.
The DDM and PDM (Drivers and passenger door modules) both communicate digitally to the BCM and the BCM communicates to Remote Control Door Lock Receiver (RCDLR) which handles communications to the FOBs. You push a button and the DDM tells the BCM someone wants the door open. If the door is locked the BCM asks the RCDLR if there is a registered FOB within 3 feet of the button that was just pushed and not within range of any of the other 4 RCDLR transmit antennas. If there is the BCM tells the DDM to start opening the door. When the DDM has lowered the window it tells the BCM it is OK to energize the latch in the B pillar. This isn't a '53 Buick. Opening a door is a surprisingly complex operation that requires the coordination of several computers. If the door starts to open but doesn't finish it is almost certain it is a mechanical problem. Either the latch or the button is intermittent and the OP eliminated that when he stated that neither button opens the door. That leaves the latch. This forum is amazing but it is also rife with "fake news".
extrapilot (05-15-2017)
As I am in another country, can anyone suggest who is good supplier for a latch? I checked Mid America but nothing there. Also Ebay and Summit.
corvettecolin (06-07-2017)
